Old 12-22-2014, 10:53 PM   #1
1989 25' Excella
Converter cables
I just replaced the Univolt in my 89 Excella with an Intellipower 9260, and used the original #6 connecting cables . Is this advisable, or a potential hazard?
PAL07 is offline   Reply With Quote
Old 12-22-2014, 11:18 PM   #2
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
#6 might be OK for the unit's max 60A output, depending on the length of the wire run. Measure the distance, multiply by 2 (you need to figure the wiring run as a round trip) and look in the 12 volt chart here:
Voltage Loss Tables for AWG Wire
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 12-24-2014, 12:49 AM   #3
New Borockton , Alabama
Images: 21
6 ga cable is adequate for a 60 amp converter/charger.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Safety Cables versus Chains Ganglin Hitches, Couplers & Balls 74 05-23-2013 11:01 PM
Charging 12V using TV and jumper cables? Boondocker Electrical - Systems, Generators, Batteries & Solar 21 06-19-2007 10:47 AM
RCA Cables for AV package Tavis76 Electrical - Systems, Generators, Batteries & Solar 3 05-19-2006 08:54 PM
Entry point for phone / other cables? krowsea Electrical - Systems, Generators, Batteries & Solar 8 08-23-2004 11:17 AM
