Old 11-16-2015, 08:39 AM   #1
PecanMan5's Avatar
2015 25' Flying Cloud
Hahira , Georgia
Converter/battery voltage
When the unit is plugged in to shore power, shouldn't the batteries read converter voltage with a multimeter? My batteries have severely depleted. The converter is working because all the 12v items are working. But checking the batteries, I am getting battery voltage, not 13.5v and will not charge.
I now have one of the batteries removed and on my shop charger. It reads charger voltage. Is there a fuse for the batteries or a protection circuit to prevent charging a depleted battery?
2014 FC 25
Barry
From my Pecan Tree
PecanMan5 is offline   Reply With Quote
Old 11-16-2015, 09:20 AM   #2
1974 Argosy 20
Kooskia , Idaho
I assume you have your USE/STORE switch in USE. If you don't, the batteries will not charge.
Old 11-16-2015, 09:20 AM   #3
timmaah's Avatar
1999 25' Safari
On , the road
Does your year have a converter wall switch that turns the converter off and back on again? Make sure that is on.
Step 2 would be to check the voltage on the output of the converter itself.
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 11-16-2015, 12:09 PM   #4
PecanMan5's Avatar
Hahira , Georgia
Am I wrong that in the store position that none of the 12v items like interior lights should be operating?
From my Pecan Tree
Old 11-16-2015, 01:42 PM   #5
2007 25' Safari SS SE
Crowley , Texas
regardless of use or store, your 12v stuff will get power from the converter as long as shore power is connected.
TopGeorge is offline   Reply With Quote
Old 11-16-2015, 03:08 PM   #6
PecanMan5's Avatar
Hahira , Georgia
Thanks all. My problem was a misunderstanding of the store/ use switch. I still find it interesting that with shore power plugged in, that the light on the switch panel tells you nothing. Unplugged it does. I am sure my batteries are well sulfated, but they are taking a charge.
It is also interesting that my Less expensive Bambi has a nice large battery switch and a large digital voltage readout.
From my Pecan Tree
Converter and voltage Emh142 Lights - Interior & Exterior 8 05-02-2014 07:03 AM
converter DC voltage varies A W Warn Batteries, Univolts, Converters & Inverters 5 08-06-2012 04:44 PM
Over voltage from my converter THEMACS3 Batteries, Univolts, Converters & Inverters 8 05-13-2012 01:20 PM
Low voltage... converter or battery problem? patrickdylan Batteries, Univolts, Converters & Inverters 5 08-22-2009 09:24 PM
Voltage Converter or not? SoccerFolks Batteries, Univolts, Converters & Inverters 5 10-09-2004 11:50 AM
