Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 11-23-2003, 05:28 PM   #1
ARGONUT's Avatar
Profile:
Images: 8
Converter/battery charger
While the sight was down this weekend, for nothing better to do , I went out to winterize our argosy and take care of the few problems i found while camping this past weekend.
The one problem was the battery would not charge up and stay up on shore power. Checked it with a voltmeter and was only getting 12.5 volts 11.4 volts with lights on.
It's a Triad-Utrad 440-6 40 amp converter charger. So i hit the internet and finally found some imformation and service bulletins on the unit. It turns out that a ground wire from the negative side of the battery and the converter was never attached to the frame of the trailer.
I wonder how long the PO had that problem with the battery?
I found 23 other things i need to fix before i stopped counting, our winters are just so long.
Johnny C.
If you can't change your mind;
How do you know you have one?
ARGONUT is offline   Reply With Quote
Best battery charger for the money? Andy R Electrical - Systems, Generators, Batteries & Solar 27 10-01-2007 08:46 PM
battery charger ALANSD Batteries, Univolts, Converters & Inverters 8 09-16-2007 06:52 PM
Solar Charger Sneakinup Generators & Solar Power 1 10-07-2003 10:04 AM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 10:39 AM
Trickle charger to replace Univolt jwaldin Electrical - Systems, Generators, Batteries & Solar 2 02-18-2003 11:12 AM
