Old 12-28-2008, 08:35 AM   #1
Cedar Lake , Indiana
converter / battery charger
Help please. My 110 is not working. I have 12 volt. No sound is coming from the inverter either. I do have 110 to the Airstream but none inside.
anyway to figure this out?
1973 landyacht
hoosiergypsy
somedaysoon is offline   Reply With Quote
Old 12-28-2008, 08:44 AM   #2
1973 landyacht
hoosiergypsy
Check the circuit breakers.
Shut them all off, then flip them back on.
Of course make sure that the trailer city power cable is plugged into a hot outlet.
Unless someone has modified the electrical system, your Airstream has a "converter" which changes the city power to 12 volts DC.
Airstream has never made a trailer equipped with an inverter, which takes 12 volts DC and changes it to 120 volts AC.
Old 12-28-2008, 09:50 AM   #3
Hi Andy,
There is a Freedom 7 inverter/ battery charger in my trailer. I have checked all of the power sources. I have looked at the fuses and reset the button on the inverter. Are there additional circuit breakers? I looked in the manual and did not see any location of any?
thank you
Hoosiergypsy
Old 12-28-2008, 10:56 AM   #4
Mexray's Avatar
1978 28' Ambassador
Morada , California
LIke Andy mentioned...check your AC circuit breakers...they are on a separate panel from your DC fuses.
In our AS, the DC panel is in the front, and the AC panel is in the rear, in the bath, as we have a rear bath setup...find that AC panel and you will be able to tell if a breaker has 'tripped' off, etc.
Ray & Pat; Morada, CA
New Xantrex Converter/Charger 68 Overlander Commercial Listings 6 07-25-2012 07:01 PM
charger / converter survey Uncle Jack Batteries, Univolts, Converters & Inverters 6 05-17-2007 10:53 PM
New Converter / Charger on the block 68 Overlander Commercial Listings 19 03-07-2007 10:54 AM
Converter/charger humming in stereo blickcd Electrical - Systems, Generators, Batteries & Solar 6 01-05-2005 07:50 PM
Converter/battery charger ARGONUT Batteries, Univolts, Converters & Inverters 0 11-23-2003 04:28 PM
