Old 01-18-2015, 10:29 AM   #1
2015 25' FB Flying Cloud
Meadow Vista , California
Converter,battery and solar upgrade
I have a 2015 FC FB Twin. It has 200 watts of solar with a Zamp controller that can handle 450 watts. What I would like to do and know if it is possible is to add an additional 200 watts of solar (is there room on the roof)? I also want to change the converter to the PD 4655, as is suggested in many posts. Lastly I would like to add additional battery storage. I am thinking two group 27 AGM's in one of the outside storage compartments. If I add AGM's would I need to replace the stock interstate batteries that are currently in the FC? I would appreciate feedback from anyone with knowledge or expertise in this area.
Thanks!
SilverSinbad is offline   Reply With Quote
Old 01-19-2015, 09:58 AM   #2
Anyone have any thoughts on this?
Old 01-19-2015, 10:57 AM   #3
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Assuming your Interstates are lead acid batteries, then yes you will need to replace them. AGMs have different charge parameters than lead acid batteries and you would be overcharging one set while undercharging the other.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
12V converter/battery/monitor upgrade dznf0g Batteries, Univolts, Converters & Inverters 35 01-31-2016 07:49 PM
Battery converter not charging battery airstreamz Electrical - Systems, Generators, Batteries & Solar 5 09-24-2014 03:55 PM
Help with Battery/Converter/Solar "issue". ShullsinUtah Batteries, Univolts, Converters & Inverters 2 11-04-2013 12:49 PM
replace and upgrade converter fuse block nikiarntz113 Batteries, Univolts, Converters & Inverters 3 11-28-2010 09:24 AM
Upgrade converter in '05 Classic 31? bandboss Batteries, Univolts, Converters & Inverters 3 03-01-2006 05:58 AM
