Old 08-04-2016, 09:55 AM   #1
1976 Argosy 28
Atlanta , Georgia
Converter & Univolt Questions
Hey Everyone!
My 76 Airstream had a working 30 amp circuit breaker box that when plugged into shorepower worked before I started working on it. However, there was NO battery, or Univolt system. There was one fuse that was near the old battery case. That was it. All the outlets worked and the AC worked. I have since disconnected the Circuit Breaker Box.
Of course now, I have purchased solar panels and two 6 volt batteries. Also a 2500 watt inverter. Since I am a newbie to electrical wiring, my question is this:
Specifically, what the blank do I need to complete my wiring system? I spoke with Randy at RV Electrical Supply and he mentioned that I do need a Converter no matter what. Is the Powermax Boondocker all I need? I guess I don't understand if everything was working without one. Also, since there was no Univolt system, what do I need to replace that?
nocmanus is offline   Reply With Quote
Old 08-04-2016, 12:04 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You need a fuse panel. Whether it be a stand alone unit or one that is combined with the shore power distribution panel and converter is up to you.
Again it will depend on the type of converter you get.
A 2500 watt inverter will take enormous wire to feed it. Unless you have a large battery bank it seems to be overkill.
What are you planning to power with the inverter?
Old 08-04-2016, 12:16 PM   #3
1976 Argosy 28
Atlanta , Georgia
A 5 Cu Freezer that will act as a refrigerator. This will be our home also (on the road). So may need to use a power tool once in awhile. I will have (4) 6 volt batteries in series for amp hours.
More concerned with the 12 Volt side of the wiring. What specific type of fuse panel?
Goucho couch,original am/fm 8 track & lots of wood & aluminum from interior remodel gquailhunter Airstream Classifieds 0 09-19-2015 05:25 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 03:59 PM
To Univolt or NOT Univolt? aircooled4 Batteries, Univolts, Converters & Inverters 11 05-13-2012 08:20 PM
need help on univolt converter 72 Overlander 1 Electrical - Systems, Generators, Batteries & Solar 90 06-25-2009 12:55 PM
