08-19-2008, 07:06 AM
1986 25' Sovereign
Allegan
, Michigan
Converter advice needed
My wife is replacing the carpet in the 86 and in the process I removed the sofa - thus giving good access to the elctrical 120 AC to 12 DC converter. It appears to be original, a "Triad ?" 50 amp unit - a bit more modern than the old "Univolt" in the 75 AS. Even though it is working properly should I replace it with a more sophisticated one?
I've read here that a "3 stage" charger/converter is desireable to increase battery life. I'm not sure that I need a 50 amp converter as I'm planning on changing to LED lighting. I did install a "Intellipower 9200" 55 amp unit in the 75 when the univolt quit - very quiet untill the fan kicks in.
I appreciate any advice/experience that you'd care to share.
Whit Nash
08-19-2008, 07:27 AM
Retired.
, At Large
The 9200 would be good for your newer coach as well. Just because it's a 55 amp converter, doesn't mean you have to use it all...
08-19-2008, 08:54 AM
Moderator Emeritus
1972 31' Sovereign
High Springs
Replace it if you can. This stuff is only going to get more expensive as time goes on. Your battery(s) will love you for it.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
08-19-2008, 10:16 AM
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English
, Hampshire
The Intellipower 9200 is a superb piece of kit. It does that thing that the best essentials do, exactly what it says on the box. I found one (new) on eBay for $ 160
08-19-2008, 10:19 AM
1993 34' Limited
Melbourne Florida
, Springfield Ohio
i also have a 1986 - what is the value in replacing the converter? Thanks.
08-19-2008, 10:27 AM
Naples
Your batteries need to be properly charged to keep them going and to assure long life. This is done with a 3-stage charging system consisting of an initial 'bulk' charge, followed by a 'tapering' charge where the voltage tapers from the high rate of the bulk phase, and finally on to the 'float' charge where a minimum of voltage is added to the batteries to maintain their voltage.
These chargers are fully automatic and read the battery voltage and provide charging voltage accordingly. The old style 'Univolts' and single voltage converters like the Triad will boil your batteries if left on due to their single voltage charging mode.
A new converter is one of the best investments you can make in your trailer.
lewster
08-19-2008, 11:33 AM
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English
, Hampshire
08-19-2008, 04:21 PM
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise
I might add that it is important to get the "Charge Wizard" which is sold separately (I think around $30). It plugs into the converter.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
08-19-2008, 04:33 PM
1984 31' Airstream310
Dunsmuir
Charge wizard is built in to the 9200 series, there is a "remote pendant" which tells you what charge mode you are in, I don't know if it allows you to override the automatic stage selection of the converter.
1984 310 Limited Motorhome
08-20-2008, 06:59 AM
1993 34' Limited
Melbourne Florida
, Springfield Ohio
Thanks for the information - a new converter is on my list.
08-21-2008, 07:18 AM
1986 25' Sovereign
Allegan
, Michigan
Thanks guys - the Intellipower gets moved today. Heading to Maine the first part of next week. Hope that the repair on the water pump fixed the leak, always some job security!
Whit Nash
