Old 08-06-2012, 07:28 AM   #1
converter
Does anyone know how to access the converter from behind the sofa of a 1989 Excella travel trailer?
murphy is offline   Reply With Quote
Old 08-06-2012, 07:55 AM   #2
SteveH's Avatar
Common Sense , Texas
You probably don't want to hear it, but I think the best way is to remove the sofa.
Old 08-06-2012, 08:51 AM   #3
converter
How do you remove the black and white wires from the converter box?
Old 08-06-2012, 08:59 AM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
If you are replacing an old Unlvolt with a new converter and have plenty of slack, just cut the wire right at the old unit. You won't lose but a couple of inches of wire.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-06-2012, 10:31 AM   #5
2005 19' Safari
GLENDALE , AZ
If you want to preserve the original wiring, perhaps for a later transfer to another RV or as a power supply for bench troubleshooting other devices, you can cut off the exposed strands flush with the insulation, and then screw on insulated wire nuts to prevent electrical shorts. After that, just tuck the wires back out of the way. You may wish to label the ends (if you know where they were originally supposed to be routed) for future reference.
