Old 03-24-2011, 12:30 PM   #1
Eric Johansen
1976 31' Sovereign
San Francisco , California
Converter
I am restoring a '76 31' Sovereign from the ground up. I have taken everything out from the inside and am putting in everything new - including refrig, microwave/convetion oven, air conditioner, electric vents, furnace, etc.
My question is what size & type of converter should I put in?
Thanks, Eric
EricJohansen is offline   Reply With Quote
Old 03-24-2011, 12:33 PM   #2
Thanks, Eric
You can use Airstreams current model, that they have used for several years, rated at 55 amps.
Old 03-24-2011, 12:35 PM   #3
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Take a look at Progressive Dynamics 45 or 60 watt Converter. Vintage Trailer Supply sells a bunch to Airstream restorers.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 03-24-2011, 01:12 PM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
I am restoring a '76 31' Sovereign ........
........My question is what size & type of converter should I put in?
Thanks, Eric
40 amp was in it new back in 76 and we use more power today. I would go with a 60 amp. Also, the price from a 45 to a 60 amp is not all that much. If it cost a nickel to go first class, go first class!
Progressive Dynamics does warrant direct. Ones does not plan to have problems, however it is always easy with them(PD), if you do
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 03-24-2011, 02:25 PM   #5
Ottawa , ON
Iota is another brand that is becoming popular. I got one last fall, I think it's a 45A, that I will be installing this spring.
Digital to Analog Converter... suggestions idmtman 2006 Safari SE 4 04-06-2011 11:01 PM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 01:17 PM
Original AS Converter Question Hummer Batteries, Univolts, Converters & Inverters 4 02-25-2011 05:22 AM
Upgrade converter? Breadbug Batteries, Univolts, Converters & Inverters 5 01-15-2011 03:08 PM
