Old 05-24-2010, 03:01 PM   #1
1971 18' Caravel
St Augustine , Florida
Control Panel Wiring Diagram
I suspect that when my AS was manufactured in 71 that all the wiring behind the control panel went to the circuit board via a spade connector and all 12 volt devices were connected the same way. Over the 39 years this fine unit has lived a few fingers have worked their majic by removing a wire here and there and some wire nuts have been added to make something work "better".
Is there a diagram in existence that I could follow to reinstate the use of the circuit board and get rid of the wiring nightmare that has evolved behind the control panel?
Thanks in advance!
Grider is offline   Reply With Quote
Old 05-24-2010, 05:16 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
The original schematic for the 75 and later models is in post #1 of this thread. Note that in the schematic, three tanks are depicted with three resistors--using this resistor ladder allowed the newer tank monitor to use only two wires per tank and still give 4 different level readings.
The earlier 70s system merely connected each tank sensor to a transistor, which switched on its associated bulb. There are four wires to the water tank (one for excitation and three level sensors) and three to the black tank (one for excitation and 2 level sensors).
The only spade lugs (from trailer wiring to the panel, their are others local to the panel) were for the ammeter. All the other connections were via a single large 12-pin connector (4-water tank, 3- black tank, 1-water pump, 2-power and ground, 1-battery, 1-blank). The battery lead was somewhat redundant, but it avoided any voltage drop that was incurred in the power wire.
Zep
68 Safari Central Control Diagram truc_05 Electrical - Systems, Generators, Batteries & Solar 7 05-26-2013 01:58 PM
1983 310 coach wiring diagram for main panel scotdo Classic Motorhomes 7 03-08-2009 07:12 AM
Control panel and wiring goransons 1959-69 Tradewind 4 07-15-2007 06:37 PM
Control Panel Wiring jronhunt Electrical - Systems, Generators, Batteries & Solar 0 10-22-2006 03:04 PM
Wiring diagram raebaker06 Electrical - Systems, Generators, Batteries & Solar 0 08-29-2004 11:02 AM
