Old 02-02-2015, 02:51 PM   #1
Dickandvicki's Avatar
1991 29' Excella
Tulsa , Oklahoma
Control Panel Short
I don't know if I am posting this in the right place, but I had a short in the control panel in my '91 Excella. The control panel is in the hood above my cook top. The tank level indicators as well as the water pump switch are all located in the hood. I have called Airstream to see about ordering a replacement hood, but this part is no longer made.
I'm just wondering if anyone knows of where I might be able to find a replacement or if there is someone that works on this type of part?
Thank you so much for the help...
Vickie
Dickandvicki is offline   Reply With Quote
Old 02-02-2015, 02:55 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
a short.. o r an open? switch, lamp? more details?
Have you 'pulled' th part off yet?
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-03-2015, 09:00 AM   #3
1991 29' Excella
Tulsa , Oklahoma
We have opened the panel. There is a plastic plug that connects the wires from the face of the panel. That white plug box overheated or shorted out and has melted together a bit. The pump switch for the water pump used to click off and on, now it's slack. Nothing on the panel works (hood light, tank level indicators, fan).
Also, around the same time one of my batteries cracked. I'm thinking I may need to also replace the converter..
Thanks so much..
Old 02-03-2015, 08:55 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup.. sounds like you need a replacement.. for sure..
Is this the board? Circuit Board Only For 511152 Range Hood W/Monitor Delux
Channing
WBCCI# 30676
Old 02-03-2015, 09:08 PM   #5
1991 29' Excella
Tulsa , Oklahoma
Thanks, CFW but my Airstream is a '91. I don't think this will work... Shoot, I don't know where I am going to find a replacement.
Old 02-03-2015, 09:09 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Is there a part number anywhere on the board or switch assembly?
Channing
WBCCI# 30676
Old 02-04-2015, 11:36 AM   #7
1991 29' Excella
Tulsa , Oklahoma
We are going pull the part this weekend.. I'll look around for the part number.. Thanks CWF
Old 02-11-2015, 04:55 PM   #8
1991 29' Excella
Tulsa , Oklahoma
I'm taking the Airstream in to an Airstream restorer.. He said he should be able to fix it for me!! Yeah!! Thanks so much for your help !
Old 02-11-2015, 05:36 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Excellent!! Good luck!!
Channing
WBCCI# 30676
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
70 Control Panel-short? rayandre Electrical - Systems, Generators, Batteries & Solar 0 04-17-2013 10:51 AM
Short -Short Ramp Lights - Interior & Exterior 0 09-12-2007 04:34 PM
The Short, Short Trailer - Spamboree flamingo-kid1 On The Road... 2 04-14-2005 01:41 PM
Control Panel Indicators niftypkg Electrical - Systems, Generators, Batteries & Solar 8 08-09-2002 03:24 PM
