Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 04-03-2007, 10:50 PM   #1
glh101282
1980 Excella II
Profile:  1980 31' Excella II
Los Alamos , New Mexico
Angry Control panel fault
1980 31' Excella. Recently added a Wallwort to power the power-on light on the control panel. Bulb was also loose so soldered it back in. After re-installing panel the battery charge lights on panel always reads "low" even though battery is fully charged (series of lights, only the first light is on, 4 lights indicate full charge). The tank level readings that are also on same circuit board/panel work fine. Think that the pink power wire that feeds power to the panel for tank levels also feeds amp info to panel battery lights. I may have fried something on the circuit board when I soldered in the bulb. Any ideas for repair or new panel?
glh101282 is offline   Reply With Quote
GM a/c control panel rdm Mechanics Corner - Engines, Transmission & More... 5 11-11-2002 07:30 PM
replacement panel maznblu Ribs, Skins & Rivets 4 09-18-2002 05:45 PM
Control Panel Indicators niftypkg Electrical - Systems, Generators, Batteries & Solar 8 08-09-2002 03:24 PM
Control Panel indicators smily Electrical - Systems, Generators, Batteries & Solar 3 07-26-2002 03:55 PM
Dented panel replaced Jim W Ribs, Skins & Rivets 1 07-08-2002 07:07 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
