10-14-2007, 10:25 PM
1999 25' Safari
Sebastopol
Constant Hum
I have a 1984 Excella 31'. I think its normal, but there is a constant hum from what I think is either the inverter or battery charger. Does this ever turn off or do I just get used to hearing it in the background?
Ben
10-14-2007, 10:30 PM
2002 25' Safari
Dewey
It's the convertor which is also the battery charger as well. It is the trademark of the Univolt. It is off when you are not hooked to city power. Upgrading to a modern 3 stage convertor is a very popular upgrade.
Richard
10-15-2007, 12:37 AM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
Ben
Hi Ben, If you really want to get rid of the hum you will need to replace your old tech univolt converter. The Intellipower is a very popular charger. Zero noise from it. Orrr... you could boon dock all the time !
The best choice would be to get something with 3 stage charging.
Do a search on 3 stage chargers for starters. Lots of info here on that subject.
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
10-15-2007, 12:40 AM
West of Fort Worth
1. Turn the stereo up
2. Turn on a fan
3. Turn on the A/C
4. Do as suggested in the posts above
It doesn't hurt anything if you can live with the hum.
Dave
10-20-2007, 03:42 PM
1989 34' Limited
toronto
, ontario
even though all these solid state inverters, converters (battery chargers), florecent fixtures have no moving parts, they do have oscilators circuits that hummmmmm, and if you are sensative to that particular operating frequency (I am to 60hz hummmm) then you are up the creek, as they say, the bigger problem is does your TV seeing that poorly designed circuit interference.
good luck
11-05-2007, 09:44 AM
1988 34.5' Airstream 345
CUMMING
, GA
I have a 1988 airstream 345 RV. The converter (30amp) has started clicking and the lights dim when it clicks. I am thinking of changing it out to an intelliverter but upgrading to a 50 amp so I can run both ACs off shore power. Does this sound reasonable to increase the amperage of the converter? Any ideas what could be causing the clicking?
11-05-2007, 09:45 AM
CUMMING
, GA
converter
er, make that an intellipower.
11-05-2007, 11:29 AM
1973 23' Safari
Tucson
I changed all the fuses and found that the humming was greatly reduced....
11-05-2007, 12:10 PM
1971 27' Overlander
Central
, Ohio
The only time ours hums enough to be troubling is bedtime - my head lays just over top it. Luckily - the PO had a switch installed that shuts off the power to the Univolt and any 12 volt outlets - but leaves all the remaining a.c. power on. So overnight you don't hear the noise - just remember to flip the switch on in the morning.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
12 volt hum
Bradjun1 |
Electrical - Systems, Generators, Batteries & Solar |
13 |
05-21-2005 09:39 PM |
