Here's what I did.
First, you should have two batteries. But that really doesn't complicate the wiring other than they are paralleled.
One set of wires that enter the battery box are for the converter.
The other set of wires is for the inverter.
I purchased a marine battery switch with Off/batt 1 /batt2 /Both.
I used the BLACK negative leads to the switch because they are longer and won't require a splice.
I sent the negative for the converter to "Batt 1" and the neg of the inverter to "Batt 2". (Seriously, I have never used the inverter yet, so I usually just switch on Batt 1).
Then the "Output" goes to the negative battery terminal.
You'll need a switch, some tools to install ring terminals, and a short piece of Black battery cable (I went with AWG 2 since it's a compromise of flexibility and capacity.)
All the red positive leads go to the battery + (Including the black jack lead with the yellow ring terminal).
Here's some links to my install. I'm rather proud of it.
http://www.airforums.com/forums/f449...ct-186724.html
http://www.airforums.com/forums/f449...-a-186725.html
