Old 10-04-2015, 05:15 PM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Confirming Converter is Toast
No 12v or 115v in the son's 69 Globetrotter. He reported the power cord plug was smoking hot. So I started troubleshooting.
All four of the breakers were on, not tripped. Main, converter, AC circuit 1 and AC circuit 2.
I found the 115v AC wires going into the transformer of the converter are dead shorted. Seems like the coil has melted down, although it doesn't smell like a shorted electrical device (e.g. motor). This converter is not a Univolt.
So if I have continuity (1 olm resistance) between black (hot) and white (neutral) going into the old converter. Should I can start shopping for another one? I'm not going to power up until I understand this.
I also found the male plug on the end of the power cord to have loose spade connectors. It is a plug that has molded rubber around the spade connectors and round ground prong. I cut it open and found the "swaged" wire ends to the spade connectors were loose. That may have generated a lot of resistance and cause the plug to get hot. A classic loose connection. A lot of fires have started that way.
Is my converter shot? I'm assuming there is a rectifier in there somewhere that might be confusing me.
David
Name:	2015-10-04 15.00.51.jpg
ID:	249614   Click image for larger version
Name:	2015-10-04 15.02.44.jpg
Old 10-04-2015, 05:30 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
In my view a bad converter wont cause no 120 volt power in the trailer, and a dead short in the converter would trip a breaker.
I think I would try replacing the faulty plug and then see whats up.
Brevi tempore!
Old 10-04-2015, 06:03 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You are right. The 115v circuits are powered by the "shore' power cord through the breaker box. Only one of the breakers goes to the converter.
I can replace the plug, leave the converter out of the picture, and verify all is good on the 115v side. I can hope the old breakers are still good.
But I sure don't know if my converter is any good showing continuity hot to neutral going into the converter enclosure.
David
Old 10-04-2015, 06:30 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It is difficult for me to guess the resistance that the devise will generate when properly working, but my GUESS is that your issue is going to be entirely due to the defective plug.
The chance of the plug and the converter going bad at the same time is not going to be large. (Especially since it didn't trip its circuit breaker).
I think the simple fix is going to be the right fix this time.
Brevi tempore!
Confirming that converter is getting charge from tow vehicle carver 1 Batteries, Univolts, Converters & Inverters 7 11-29-2013 02:24 AM
Toast Noco Interior Restoration Forum 10 05-19-2013 06:27 AM
Are my batteries gonna be toast? Gringo Batteries, Univolts, Converters & Inverters 38 10-13-2012 01:01 PM
How Do You Make Toast? Fly at Night Stella's Kitchen 38 09-12-2011 02:49 PM
How do you make toast ???? polarlyse Stella's Kitchen 40 05-15-2010 05:18 PM
