Old 08-31-2008, 06:25 AM   #1
64TrotterAtl's Avatar
1964 19' Globetrotter
Decatur , Georgia
Complete Rewire
I am in the planning stage of re-wiring my 64 GT. I cannot seem to find threads where people have documented the upgrade and complete rewire with pictures. I am going to be adding a converter/inverter, new panels, all new wiring. But, I really need to educate myself before doing all of this, not that I am ignorant, but I want to visualize what others have done.
Please help, ANdrew
64TrotterAtl is offline   Reply With Quote
Old 08-31-2008, 06:31 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Are you going to rewire 120 volt, or 12 volt only? If you are going to remove interior panels to rewire one, you should rewire both.
The 12 volt feeds go down the center top panel, and branch off from there. You could "pull" the wires down from the center to whatever you are wanting to rewire, it may help keep panel removal to a minimum. 120 is a slightly different story.
Old 09-01-2008, 06:28 PM   #3
Decatur , Georgia
After researching over the last 24 hours, I am going to rewire everything with a 50 amp service that has 120 volt and 12 volt. Mainly the 120 will run the fridge, ac, outlet for laptop, an outlet for a microwave and an outlet for a toaster oven. I am going to add a GFI outlet for outside power. The 12 volt will run the lights, water pump, etc...What are your thoughts
Old 09-01-2008, 07:08 PM   #4
1969 29' Ambassador
orange Park , Florida
Yes if you are going to do a rewire might as well do everything including the trailer running lights and turn/ brake lights, clearance lights. If you are pulling the interior apart just replace the wires one or two at a time, or mark what wires go where so you don't get lost in the middle of rewire. Take lots of pictures before you start, there will be 12 volt wires running everywhere, from fuse panel to lights,fans,fridge, and to water pump,furnace, and ac controls(thermostat). If you are gonna replace the convertor and 12 volt fuse panel start there and document your wire colors and where they went and from what fuse, this will help in later diagnosis if something should go wrong in future. If everthing in trailer gonna stay in same area;IE fridge,water pump,fans ect, i wouldn't just rip everthing out at once. Just go at it slow and replace wires 2 or 3 at a time.
69AmbassFl is offline   Reply With Quote
Old 09-01-2008, 07:37 PM   #5
65CV's Avatar
Western , Massachusetts
Here's my first draft
I haven't started the wiring yet. Just finished skin replacement.
Here's a draft that, honestly, I haven't looked at for months. Time to start thinking about it soon!
Note that it doesn't include brakes or running lights.
John
65CV is offline   Reply With Quote
Old 09-01-2008, 07:39 PM   #6
65CV's Avatar
Oh, yea
... I should say that the schematic on the previous post is for a 17' Caravel, 2 gaucho model.
We became convinced at the open house at the Vintage Trailer Jam to do a dinette, but haven't updated the design.
John
Old 09-01-2008, 08:01 PM   #7
87MH's Avatar
1978 31' Sovereign
Images: 292
Two separate electrical services
Originally Posted by 64TrotterAtl View Post
After researching over the last 24 hours, I am going to rewire everything with a 50 amp service that has 120 volt and 12 volt. Mainly the 120 will run the fridge, ac, outlet for laptop, an outlet for a microwave and an outlet for a toaster oven...What are your thoughts
Instead of a single 50 amp, why not wire up a 30 and an additional 20 amp line? Many campgrounds only offer a limited number of 50 amp connections - the 30/20 split would seem to be more versatile.
When I redid the Sovereign I installed an additional 20 amp connection...http://www.airforums.com/forums/f219...ign-14737.html ...#45 and #46. The extra 20 amp service is for the electric/gas water heater, but the second entrance line may well do double duty if I would mount a second AC on the unit - of course, the second AC would not be necessary on your Caravel.
With either connection (30/20) you still could only operate one major power draw (AC, Water Heater, MicroWave, Toaster, etc) on each service, but with the two services things are much more easily deployed.
A 50 amp adapter with two pigtails (a 30 AND a 20 amp amp line) does not take up too much room when travelling.
Do not scrimp on the gauge of the electrical lines - use a 10 guage line for the 20 amp line, and a #6 or a #8 for the 30 amp side.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 09-09-2008, 07:41 PM   #8
Decatur , Georgia
So, I am not sure if I actually need the 30/20 split. I am really thinking that a 30 would be sufficient. My electrician buddy was telling me to do the 50 amp service.
In terms of converters/inverters, what is a good option for me, something that will charge my batteries (3 stage charger). I have seen some that cost $1,500, and I definitely don't want to spend that much. Is there a powerfull model that offers me everything that a $1,500 inverter/charger offers?
I am going to look over the schematic that was provided in an earlier reply to this thread. I am just now finishing up putting the shell back onto my new subfloors. You can see the blog on the portal page "64 GT Restoration"
Anyone want to sell me on a inverter/converter with all the bells and whistles, for a good price??? please, Andrew
Old 09-09-2008, 08:13 PM   #9
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Rewire Advice
Yes, lets keep this thread going. I too have to rewire everything. Was planning on power washing the interior first. Just worried about loosing track of all the old wires and their routes.
1956Safari is offline   Reply With Quote
Old 09-09-2008, 09:59 PM   #10
Ottawa , ON
Attachment 67160
Jeez, it looks like you already did powerwash the inside! Très clean.
Old 09-10-2008, 04:44 AM   #11
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Adnrew,
Have you checked out Bestconverter.com? Randy is a forum member and has quite a selection of converters, inverters, and chargers. He is also reasonably priced and quite knowledgeable.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 09-10-2008, 08:01 PM   #12
Decatur , Georgia
Originally Posted by DEITZ645 View Post
Adnrew,
I am going to check his website out right now. Thanks in advance.
I finished my sub-floor install today. Black tank is in place and the floors are attached. Now it is time to put the shell back on and have it look like an airstream again.
Sorry, off the subject. Anywho, I will let you all know what I decide to install, or rather, what I find is the best for my situation.
Old 01-07-2015, 12:11 PM   #13
1966 20' Globetrotter
Starkville , Mississippi
Great Thread!! How much did you spend on the full rewire? Thinking of doing this to my 66 GT but dont want to spread myself to thin.
ductwrap is offline   Reply With Quote
230v to 120v stepdown transformer or rewire? finn2020 Batteries, Univolts, Converters & Inverters 9 04-05-2007 07:09 AM
1967 Overlander 110v rewire TNBUBBA Electrical - Systems, Generators, Batteries & Solar 1 10-09-2006 10:17 AM
54 safari rewire durans54 Electrical - Systems, Generators, Batteries & Solar 2 01-18-2005 03:52 PM
Should I just rewire it? 63air Electrical - Systems, Generators, Batteries & Solar 5 08-29-2004 09:55 AM
Rewire with Copper McMullen 1966 Overlander 4 11-18-2003 03:08 PM
