Old 07-29-2016, 12:35 PM   #1
Hampton , Virginia
Complete and utter newbie question
Not just a newbie, but a rather ignorant one too....
I've been looking a trailer that someone has completely made into a 110volt system. has no batteries.
What would I have to do, and about how much would it cost, to reinstitute a dual system? I wouldn't want to limit myself to only hookups with power.
Thanks for any insight.
Getaways is offline   Reply With Quote
Old 07-29-2016, 12:53 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
It is hard to say without knowing how much he may have removed. The convertor, the batteries will cost $400.00 or more. Fixture replacement you can get prices from a trailer company web site. Did he remove the 12 volt wiring if so it will be real time to replace it. How is the frig controlled and is the hot water heater pilot light only
There are lots of trailer for sale out there and unless you have a death wish look elsewhere. But if the price reflects his stupidity, at least 1/2 the competition, you will be taking a salvage project on.
2004 Excursion 4x4
Old 07-29-2016, 01:51 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
What year and model is the trailer? There were some trailers that were bult as "park models" that never had 12V wiring in the first place.
Old 07-29-2016, 02:03 PM   #4
Hampton , Virginia
1993 Sovereign 21 footer.
Old 07-29-2016, 02:05 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Your question is wise. The foolish question that we get all too often on this forum is about how to make a trailer 110 volt only.
Usually in 110v conversions someone replaces the fridge with a 110 volt fridge that won't run on propane. This is the most difficult and expensive change to reverse. Prices on fridges vary widely depending on size. You can check prices yourself. Depending on the history of the trailer you may also have to replace the water heater, stove, furnace, propane bottles, and regulator, if these components were discarded as they all too often are. Building up a whole propane system from scratch will cost at least $2,000 and is a prerequisite for running a trailer without 110 volt.
As far as the 12v system itself, here's materials cost. You'll find that the converter, battery box, batteries, breaker panel, wire, terminals, and ancillary components will run abour $400-$500 or so for a basic system with a 55 amp converter and a single group 27 battery. Lighting and switches don't have to be expensive, but can be if you have taste and get yacht-quality LED lights. Under $100 is possible as is over $500. The remaining components are typically three fans (range hood, bathroom, living room) and a water pump.
The labor to put this all in is considerable. It usually isn't possible to fish wires through the walls, so if the existing wiring is gone, you'll either have to remove panels or run wiring on the surface.
Old 07-29-2016, 03:08 PM   #6
Gainesville , Florida
You need a battery to activate your legal breakaway switch. It's the law.
Old 07-31-2016, 03:44 PM   #7
1971 31' Sovereign
Temple , Texas
breakaway switch
There are breakaway switches which have their own built-in battery. They don't require an external 12V battery.
TxDave is offline   Reply With Quote
Old 07-31-2016, 08:48 PM   #8
1986 31' Sovereign
Miami , Florida
A breakaway switch with a battery that will supply enough current to lock up all four electric brakes?
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 07-31-2016, 09:13 PM   #9
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
One other area of consideration you may want to double check on regarding this particular trailer is what else has been modified from factory design?
I mention this because the factory engineers designed the location, physical size, and weights of everything to make the trailer safe and stable when being towed. If this has been altered then the trailer may no longer be safe and stable when being towed.
People who are good at restorations will actually weigh the items removed during tear-out to make sure they do not replace with new items that are too heavy. Doing so could change the weight on the frame, tongue, etc.
Original documents can be downloaded on the airstream website.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Complete newbie... Astro2 Member Introductions 6 06-10-2016 01:02 PM
complete newbie, already needing a shell off? joesheehan Repairing/Replacing Floor &/or Frame 9 03-02-2011 07:39 AM
Hello- Utter newbie here Capt Quirk Member Introductions 14 11-09-2010 08:09 PM
Complete door lock and assembly for a 72,am I doomed? Pkerr Exterior Storage Compartments & Access Doors 10 10-25-2009 07:05 PM
Complete floor replacement and chassis refurm photos Jonz Repairing/Replacing Floor &/or Frame 0 09-16-2007 07:37 AM
