Old 06-05-2010, 09:36 PM   #1
PBStrother's Avatar
1966 22' Safari
Cologne , Minnesota
CO detector sounds
We have a new to us (two weeks) 1966 Safari in very good condition. When on shore power and with the switch "Rectifier" on, after a few hours the CO detector sounds, indicating 150 ppm CO. Venting the unit solves it. Hooking it to shore power with the "Rectifier" switch off doesn't trigger the detector. What's happening here? The LP is off at the tanks.
PBStrother is offline   Reply With Quote
Old 06-05-2010, 09:59 PM   #2
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Welcome aboard.
I don't know the answer to your question but there are those here who will. I'm curious myself.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 06-05-2010, 10:45 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Boiling the battery will set off a CO detector. When the Univolt failed in my Trade Wind, the CO detector woke me up in the middle of the night.
Vaughan
Old 06-05-2010, 10:47 PM   #4
PBStrother's Avatar
1966 22' Safari
Cologne , Minnesota
Is there a way to confirm the demise of the Univolt?
Old 06-05-2010, 11:03 PM   #5
1983 34' Excella
1967 24' Tradewind
Images: 32
Well, the battery was boiling. Literally, not a figure of speech. It was overcharging that much. When I opened the compartment I could feel the heat and the fumes were terrible. I guess you want to find a way without reaching that extreme, though.
You could check to insure that the battery is fully charged by checking its voltage after disconnecting from power for a while. Then, turn the power on and check for excessively high voltage.
Realistically, in my opinion, Univolts were born not working. OK, they were good for their time, but converter technology has really improved since then. I replaced the completely functional Univolt in my 1983 Excella with a Progressive Dynamics Inteli-Power just to get the improvements. (See http://www.airforums.com/forums/f449...0-a-57567.html) These include better battery life, less chance of running the battery cells dry, quiet performance, and a clean 12 volt DC supply for electronics. Besides, I didn't want to wake up again to the CO detector.
Vaughan
Craigslist - Sounds too good to be true! coffeydelsol Trailer Values 8 03-03-2009 08:10 AM
Sony DVD Player, sounds? SilverBreeze Audio, Video & TV 6 01-20-2009 08:44 AM
This place sounds great!?!? hotLAVA On The Road... 6 07-09-2006 11:17 AM
Furnace questions and scary sounds in turns amathis55 Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-07-2006 05:05 PM
New A/C in CCD makes chirping sounds cmock Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-02-2004 02:03 PM
