Old 03-26-2016, 12:59 PM   #1
1976 31' Sovereign
Edmonton , Alberta
City Power Help
We just got a 31 foot 1975 Sovereign and picked her up yesterday. We had a dealership inspect it before we bought it and they said everything was in good working order. However, we can not figure out how to get the city power to work. It's plugged in, but not providing power to any of the outlets. Is there a power switch we are missing. I know this is going to end up being something obvious, can anyone help?
Cross_Winds is offline   Reply With Quote
Old 03-26-2016, 01:04 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Power switch behind the couch. rotary two position.
Old 03-26-2016, 01:07 PM   #3
1976 31' Sovereign
Edmonton , Alberta
Hmm... I don't see anything behind the couch.
Old 03-26-2016, 01:12 PM   #4
1976 31' Sovereign
Edmonton , Alberta
You mean the front couch?
Old 03-26-2016, 01:22 PM   #5
1994 34' Excella
Warren , Manitoba
Check the main breaker panel. On my 1976 rear bedroom Sovereign it was in the nightstand on the left side of the bed. If you have a rear bath it is usually in the closet. Make sure the main breaker is "on" and the other breakers are "on". Good luck, Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 03-26-2016, 08:11 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Always hard to figure these out over the internet. Here are some things to try.
- As CBWELL points out, there's a breaker panel somewhere. Find it, and confirm that the breakers are all on. Use a flashlight if necessary.
- It is possible that the city power outlet you are using isn't working, or is shut off at its breaker.
- It is possible than any adapters or extension cords you are using aren't working properly.
- There may be a wiring problem that the dealership missed.
water dripping from city water hose attachment location when NOT hooked up to city wa Wilmington Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
59 Tradewind 'City Power' electrical problem xposure285 Electrical - Systems, Generators, Batteries & Solar 20 07-16-2009 10:13 AM
City/Battery Power Switch Broken? '63 Safari DenverAaron Electrical - Systems, Generators, Batteries & Solar 8 10-06-2006 09:32 AM
How Long without City Power The Flintstones Generators & Solar Power 7 09-27-2006 01:02 AM
