Old 07-11-2007, 10:00 PM   #1
2007 25' Safari FB SE
Blaine , Washington
Checking the water in the batteries
My 07 Safari has the battery cables laying across the water caps with little or no slack. In order to check the water I have to remove one end of the cables.
Is there an easier way? Can I buy longer cables and lay them alongside the batteries as they traverse between the batteries?
Thanks;
John
Relentless is offline   Reply With Quote
Old 07-11-2007, 10:21 PM   #2
cammur's Avatar
Roseville , California
Pain in the butt, isn't it?
I've been able to pry the caps up enough to check the cells without removing the cable, but just barely.
No answer for you, just sympathizing.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 07-11-2007, 10:23 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
When your battery dies. Replace it with an AGM.
Richard
Old 07-11-2007, 10:58 PM   #4
TIMEMACHINE's Avatar
Huntington Beach , California
Agreed
Richard has the best advice on this one.
John
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 07-12-2007, 10:28 AM   #5
I just bought some longer cables from Wal-Mart, long enough so that the batteries will slide out and can even be lifted down onto the ground, though I usually just rest them on the open door flap. The excess cable can be folded or coiled loosely beside the batteries. I then use one of those battery water dispensers that only dispenses when the container is pressed firmly down onto the battery cell opening. When the correct level is reached, the air supply tube in the nozzle is submerged, and the distilled water ceases to flow.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 07-12-2007, 10:37 AM   #6
lewster's Avatar
Naples, FL , Hood River, OR
Richard and John are spot-on with their advice for AGMs. I am a huge fan of them, sell them, and have replaced every lead-acid battery that I own with them. Better capacity, much faster re-charge times, mostly bullet-proof, and the Lifeline brand is built to mil-spec and used in all of our military's aircraft.
That said, if you don't want to go that route, follow Nickcrowhurst's excellent advice.
Old 07-12-2007, 11:20 AM   #7
pamelake's Avatar
1974 25' Tradewind
Lake Oswego , Oregon
So, do AGM (?) batteries not require water? More info please!~ Pam
pamelake is offline   Reply With Quote
Old 07-12-2007, 12:51 PM   #8
Stream 1529's Avatar
2004 34' Classic S/O
San Antonio , Texas
I went to the lifeline webwite, and it got my attention. What size AGM batteries would I need for my 34'AS.
______Tom
Blog: www.travelpod.com/members/wbcci1529
'04 34' Classic S/O lounge, dome king, twin a/c, faux fireplace to keep the wife warm , equa-li-zer, prodigy, 4 birds, dog - no kids allowed!
'05 Excursion 4x4, 6.0 PSD, magnaflow, helwig anti-sway, air lift springs.
Stream 1529 is offline   Reply With Quote
Old 07-12-2007, 01:12 PM   #9
2002 25' Safari
Dewey , Arizona
Images: 62
______Tom
The biggest one that will fit. In my 75 TW it was a Grp 27 Lifeline....
Richard
Old 07-12-2007, 02:11 PM   #10
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
When the Intersates die they will be replaced by AGM'S. But for now the longer cables we installed after our first battery ck are working just fine. It's funny how one cable is plenty long enough,but the other way to short!!! NOTE: get good quality cables of the PROPER guage, also if your plugged in or on a generator for an extended period; ck level once a week, I was quite surprised how quickly the level went down compared to our beloved "63" Safari.
IF YOU DON'T KNOW WHERE YOUR GOING ANY ROAD WILL TAKE YOU THERE<><>
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-12-2007, 11:33 PM   #11
lewster's Avatar
Hi Pam,
Go to Lifeline Marine Batteries - AGM Marine Battery & AGM RV Battery for all the info you seek. They DO NOT require any maintenance, other than keeping them charged. The benefits are many....the only detriment is the cost!
I have 2 GPL-4C golf cart batteries in my CCD and just ran them for 5 days of dry camping...lights, 2 fans, refer, all on DC. They were at 75% after all of this and were still running everything when I finally 'plugged in'. I use no other type of battery in any of my vehicles.
Old 09-21-2007, 09:03 AM   #12
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
A couple of questions on batteries;
After toasting a pair of batteries a few years ago, I have learned to maintain them regularly.
· I check the fluid level once/month and top off if needed with DW. There always seems to be a little “sweat” on top of the batteries. Sometimes it even dribbles out the front of the battery compartment causing a little corrosion. Am I over-filling? Batteries are not “boiling.” I still have original uni-volt.
· If I am not running the fridge (plug it in a few days before a trip) I unplug the shore power and run off the batteries (just a few lights if we happen to go inside). I do this as I understand the uni-volt is not the best charger and don’t want to boil the batteries. Is this good practice?
· Is it worth switching over to AGM’s if I still have the uni-volt? Or is that a waste of expensive batteries?
Thanx, Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 09-21-2007, 09:55 AM   #13
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Hi Lew et al,
I just spoke with Batteries Plus about the Lifeline GPL-4. The cost for ONE of those batteries is over $400.00! Yikes. Two at $800.00 plus shipping would cost me a trip out in the AS.
On top of that, they mentioned that the life expectancy of those batteries if well maintained would still be about 5-6 years.
I was interested in these until I heard that.
A single Interstate SRM-24 batery is less than $80.00, if you return an old battery. I've had my original Interstates for four years. So the decision to spend $160.00 every three years (at worst) verses $800.00 every six years (at best), I would still be spending only $320.00 verses $800.00.
Was the sales guy I talked with completely off the mark????
Still wonder and still love your advice.
Best wishes.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 09-21-2007, 10:16 AM   #14
lewster's Avatar
Rally now!?!?!?
Originally Posted by crazylev
Hi Lew et al,
Best wishes.
Jonathan
Jonathan,
I think this guy is yanking your chain! Yes, the Lifelines are exensive but I don't recall the GPL-4GC 6volt batteries costing anywhere near $400 each!
I'll check with my supplier and get you the current MSRP for those, or any other size you would like.
Water Hammer smily Water Heaters, Filters & Pumps 10 02-08-2003 04:18 PM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
