Old 08-12-2009, 05:30 PM   #1
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Charging voltage?
We've just been away with the trailer for a short one week trip.
Before we went, I plugged a digital battery condition meter into a 12v socket in the bedroom and kept an eye on it all week while we were plugged in to 110v.
Every time I looked at the meter it registered either 13.8 or 13.9v.
I'm just wondering if this is normal?
Should I not at some times be reading a voltage somewhat lower as the charger cycles on and off, or am I in fact seeing the voltage that the converter is putting into the trailer's wiring system which may not be the same as what it is delivering to my coach batteries?
Just don't want to ruin the new agm batts I just put into the trailer!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-12-2009, 05:35 PM   #2
SteveH's Avatar
Common Sense , Texas
13.8 Volts is the normal charging voltage, and the converter does not cycle on and off charging the battery in its factory configuration.
If however, you disconnect from AC power, the battery voltage should then slowly go down to 12.6, or so, with no load.
Old 08-12-2009, 05:37 PM   #3
TankerIP's Avatar
2002 22' International
2019 25' Flying Cloud
I'm not an expert, but when I check voltage it varies with what is turned on and operating at the time. Since you raised the question, I would have to do a test to see if the internal trailer charger drops voltage as the the batteries approach full charge. I hope someone else has this all researched.
TankerIP is offline   Reply With Quote
Old 08-19-2009, 05:03 AM   #4
1984 31' Excella
Broken Arrow , Oklahoma
Images: 11
Converters
Go on line for the type of converter you have. Each manufacturer will have information (at least mine did) concerning charge rates/current/voltage.
All your questions should be answered there.
Beginner
Beginner is offline   Reply With Quote
Old 08-23-2009, 10:51 PM   #5
New Borockton , Alabama
Images: 21
13.9 is fine if you are using the Airstream on a regular basis and drawing from the battery but in time, especially if you don't draw it down much, it will start to gas the water out. I like 13.6 as a nominal everyday voltage output. Those tenths do make a difference in a few weeks or months.
I really think the higher voltage during bulk is best, even up to maybe 14.8 is safe but the float needs to be 13.5 or even lower in hotter climates if you store your unit in the summer.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 08-23-2009, 11:16 PM   #6
mandolindave's Avatar
13.8 volts is normal...but it depends on what kind of charger you have. The new high end chargers are three stage, and go in to trickle mode when the batts are charged. And actually a 12 volt batt isn't a 12 volt batt. 12 volts is actually considered dead.
You have to give batts more voltage than they are rated at to get them charged.
Kind of like when you have to pay a mandolin player more than they are really worth.
mandolindave is offline   Reply With Quote
Old 08-24-2009, 06:30 AM   #7
Images: 59
If the voltage is too high, the battery will get hot and give off noxious gases. If you pay the mandolin player too much, will he exhibit a similar physiological condition?
voltage at battery? 3Ms75Argosy Electrical - Systems, Generators, Batteries & Solar 1 07-27-2005 04:25 PM
Best voltage for A/C? TomW Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-12-2004 08:09 PM
Univolt Voltage Joe62984 Electrical - Systems, Generators, Batteries & Solar 5 03-01-2004 01:58 PM
Voltage Regulator Rayk Airstream Motorhome Forums 2 09-16-2003 06:36 PM
Low voltage-A/C Dave-O Electrical - Systems, Generators, Batteries & Solar 10 04-24-2003 07:56 PM
