Old 10-17-2015, 01:53 PM   #1
2010 25' FB Flying Cloud
Spring , Texas
Charging Puzzlement
2010 AS Flying Cloud disconnected from tug and connected to 110vac. All DC and AC devices work. Exception: No voltage at ends of battery terminals when terminals disconnected. Batteries will not charge unless connected to tug. All breakers OK. Help please.
Froggy2 is offline   Reply With Quote
Old 10-17-2015, 01:57 PM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Please clarify. Between positive battery terminal and what? Measured how?
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-17-2015, 02:12 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Check the fuses on the output side of the converter.
Make sure the 110 receptacle for the converter is hot at the receptacle not just the breaker.
Checking the wires to the battery may not be a good check if the converter has a circuit that sense an open circuit.
2004 Excursion 4x4
Old 10-17-2015, 02:17 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Is the store switch off?
Old 10-17-2015, 02:33 PM   #5
Spring , Texas
Measured from positive battery terminal with cable connected to negative battery cable, cable disconnected. Measured with voltmeter showing 0.004VDC.
Old 10-17-2015, 02:33 PM   #6
Spring , Texas
Switch in on position.
Old 10-17-2015, 04:12 PM   #7
HowieE's Avatar
Images: 12
Can you restate this. Where were the probes of the voltmeter placed and what cable was disconnected.
Have you checked to see if the converter has power to it and if the output fuses of the converter are good?
2004 Excursion 4x4
Old 10-17-2015, 05:13 PM   #8
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Voltage is measured in parallel. You should have your batteries connected while measuring the charging voltage at the batteries. If you are getting 12.7 volts or less you are measuring battery voltage and your converter is not sending charge current. Around 13.4 or more you are getting a charge.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 28 12-16-2017 06:32 AM
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 10:22 AM
Charging AC on 71 overlander smily Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-25-2002 05:33 PM
Charging System drmmlien Electrical - Systems, Generators, Batteries & Solar 3 05-09-2002 01:53 PM
