Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 12-29-2007, 09:47 AM   #1
Kevin245
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Charging Battery While Plugged in to Shore Power
We are taking in a short weekend in the mountains and I'd like to top off the battery before the Winter break of two months. Is it safe to put an additional charger on the battery while we are plugged in to shore power?
I still have the "Buzz-Volt" and it won't top off the battery on such a short turn around.
Kevin
Old 12-29-2007, 11:52 AM   #2
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
And the long distance thru the umbilical from your TV alternator probably won't recharge the battery on the trip home. I'd probably put a charger on bare terminals just to be sure -- more out of lack of knowing about a reliable recharge if you leave it hooked up.
Old 12-29-2007, 01:10 PM   #3
Leipper
Profile:
It should be 'safe' to connect a charger in parallel with your converter. Whether it will really top off the battery depends upon the charger. Even a capable 3 stage charger should be applied for ten hours or so to assure a full charge.
For 2 months storage, you need to make sure the battery has a full charge and then disconnect it and make sure it is cleaned of any corrosion or surface dirt. If the battery is kept cool, it shouldn't discharge more than 20% or so and shouldn't suffer too much. (wet cell batteries just don't like sitting still, especially without a full charge as that allows slow but sure sulfation)
It is much better to put a trickle charger with desulfation capabilities on your battery when it is not in use. The Battery Minder plus or the PD/Charge Wizard converter or the MFCO converter are examples of devices that do this. Care is needed to make sure this charging does not cause significant electrolyte loss.
Bryan
Leipper is offline   Reply With Quote
Shore Power Again The Flintstones Batteries, Univolts, Converters & Inverters 13 10-09-2007 07:18 PM
Univolt/ battery/ shore power question Lumatic Batteries, Univolts, Converters & Inverters 6 05-21-2007 08:10 PM
Battery/Shore power problem Aussie70 Batteries, Univolts, Converters & Inverters 18 05-14-2007 07:55 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
