Old 04-17-2013, 03:25 PM   #1
astrocaver
1986 25' Sovereign
Denver , Colorado
Charging batteries from external source
When using an external generator or solar pannel how do you put that power into the trailer. The battery box on my '86 Soverign is small and not condusive to just clamping cables on the battery terminals.
astrocaver is offline   Reply With Quote
Old 04-17-2013, 03:28 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
When using a generator, you just plug the trailer's 30A shore-power cord into the generator directly (it will require an adapter.) The built-in converter/charger will charge the batteries just like it does when you're plugged in at a campground.
Solar panels are generally wired directly into the 12v system so that they'll charge the battery anytime there's sun and the battery needs a charge.
David
Old 04-17-2013, 03:35 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use circular wire connectors to wire my portable 3-stage battery charger directly to the battery with a pig tail into the interior of the trailer to plug the charger into. I use the same system for solar panels on my sail boat. I have never used a generator with my trailer so have no actual experience in wiring one in to the trailer system. On the boat I simply plug the generator into the boat/house power plug when needed.
MICHAEL
Motorhomes, and Charging Batteries.... Keyair General Motorhome Topics 18 10-15-2011 08:21 AM
Charging batteries Moflash Batteries, Univolts, Converters & Inverters 21 07-19-2011 11:07 AM
Bad Batteries? Nightwatch Electrical - Systems, Generators, Batteries & Solar 8 05-23-2011 01:58 PM
