Old 12-12-2007, 03:04 PM   #1
2004 19' Bambi
Denver , Colorado
Images: 32
Charging Auxiliary Batteries
Well, this isn't really a repair (or even an Airstream) related question but maybe someone can answer it for me ...
I carry 2 12-volt (in parallel) auxiliary batteries mounted in the bed of my pickup to provide 110v AC through a 300 watt inverter to power some AC work tools at remote job sites. I know that my truck's alternator charges my trailer batteries when I am towing so my question is this: is there a way to tap into my 7-pin wiring harness and connect my auxiliary batteries to my existing electricals and have the batteries charge off my truck alternator when it is running?
Thanks in advance for any info on this.
COLORADO_CAMPER is offline   Reply With Quote
Old 12-12-2007, 03:37 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
You will need a battery isolator like this
Powerline Multi-Battery Isolator
Old 12-12-2007, 04:19 PM   #3
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin , 28734
You will also need a lager alternator or on some trucks you can have two altenators. One will ont handle three battries unless it is a heavy dudy unit.
Ramp is offline   Reply With Quote
Old 12-12-2007, 04:44 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
You would probably be better off by charging them at night by a 3 stage charger plugged in to your home via extension cord and using a solar panel to keep them charged all day while out on the job site. Check with Northern Tool for somenice chargers....both 3 stage and solar.
Old 05-27-2008, 04:01 PM   #5
Woodside , New York
So can this be done?
"is there a way to tap into my 7-pin wiring harness and connect my auxiliary batteries to my existing electricals and have the batteries charge off my truck alternator when it is running?"
Just looking to recharge one battery, so I can have lights and run a water pump from time to time.
Geno is offline   Reply With Quote
Old 05-27-2008, 04:55 PM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You can tap it at the 7 way plug, but you can just run a wire to plus pole of the regular battery and hook on with a clip when you need to charge. A battery isolator lets you charge the truck battery and the extra but keep them electrically separate. Without an isolator, if you leave the aux connected, you can drain the main battery too and not be able to start. Our PU has a winch, so I have two batteries and a selector swtch and an isolator. When I need to use the winch I select either battery, but not both so that if I run one down, I still have the other to start back up.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-02-2008, 07:17 AM   #7
Woodside , New York
So if I had a plug with only one black wire, removed the other six wires, then attached that black wire to the positive post on the battery, while driving, it would recharge the battery?
No negative wire is needed?
Thanks all
Old 06-02-2008, 08:38 AM   #8
Aerowood's Avatar
Arvada , Colorado
You will need the ground too
Old 06-02-2008, 08:21 PM   #9
lewster's Avatar
Thanks all
Like Aerowood says, you need the ground too. You also might look at a little device called an 'echo charger'. This will enable you to charge your battery from the TV battery directly, as it acts as a charge controller of sorts.
Old 06-09-2008, 10:16 AM   #10
Woodside , New York
Aerowood and Lewster,
Thanks to both of you.
Geno
Batteries not charging while driving wildwoodrver Electrical - Systems, Generators, Batteries & Solar 36 08-22-2008 05:33 PM
Auxiliary Water Heater grovelander Classic Motorhomes 10 12-10-2007 07:43 PM
GMC Diesel and charging batteries while towing SRoffe Mechanics Corner - Engines, Transmission & More... 17 09-17-2007 08:28 PM
Auxiliary batteries won't hold charge Lena Abbott Batteries, Univolts, Converters & Inverters 5 09-26-2006 06:36 PM
Charging AGM trailer batteries from vehicle mswartz Batteries, Univolts, Converters & Inverters 5 05-15-2004 02:34 PM
