Old 12-29-2019, 07:09 PM   #1
2019 19' Flying Cloud
Port Charlotte , Florida
Charging
I have a 2019 19CB Flying cloud unit. I am having problems with my charging system. When I am plugged in to 30A power my batteries do not appear to be charging. How can I check to see if the converter is working?
Mattmcelroy is offline   Reply With Quote
Old 12-29-2019, 08:22 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
If the converter is working you will have between 13.2v and 13.6v in the trailer when plugged into shore power.
Make sure your battery disconnect switch is on yo charge the batteries.
wulfraat is offline   Reply With Quote
Old 12-29-2019, 08:51 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Depending on how you specific trailer is wired, the use/store switch may have an impact on charging.
1) Check the 120V AC into the charger with your DVM. No power in means the breaker is tripped or there is a wiring fault.
2) Check the voltage on the output terminals of the charger. It should be above 13V DC.
3) Check the voltage at the battery terminals. Again you should have above 13V DC.
uncle_bob is online now   Reply With Quote
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 29 09-08-2018 09:12 PM
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 03:50 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 11:22 AM
Charging AC on 71 overlander smily Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-25-2002 06:33 PM
Charging System drmmlien Electrical - Systems, Generators, Batteries & Solar 3 05-09-2002 02:53 PM
