Old 05-31-2019, 12:06 PM   #1
2017 25' Flying Cloud
Brixey , Missouri
Charger Fuse
I'm looking for the fuse from the converter/charger to the batteries. should be around a 50 amp fuse. this is in a 2017 25 Ft FBT FC. 50 amp system. I see the fuse panel with all the 15 amp fuses but this should be different. I'm using a Boondocker 1260HD charger. charger runs constantly and batteries are dead. two 6 volt full river batteries only 6 mo old and have been working fine until a day ago. I could tell something was wrong when the converter fan never shut off, with no 12 volt systems on. Upon checking battery voltage I found they were dead. must be a fuse somewhere.
O'Reill's says the batteries are bad. I'm not sure they have the right equipment to check deep cycle and having two go bad at the same time - what are the odds? Charger works fine in the shop, don't think that's the problem.
Stevenb is offline   Reply With Quote
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
Power Converter / Battery Charger / Fuse Panel susans69 Batteries, Univolts, Converters & Inverters 34 06-21-2012 10:19 AM
Best battery charger for the money? Andy R Electrical - Systems, Generators, Batteries & Solar 27 10-01-2007 07:46 PM
battery charger ALANSD Batteries, Univolts, Converters & Inverters 8 09-16-2007 05:52 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
