Old 11-10-2012, 01:17 PM   #1
TetonStreamer
Teton Stream's Avatar
2017 23' Flying Cloud
Wilson , Wyoming
Charger for AGM Batteries
If I install a pair of Lifeline Group 27 AGM batteries in my Bambi do I need to change out the factory installed battery charger?
Teton Stream is offline   Reply With Quote
Old 11-10-2012, 01:53 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Teton Stream,
If you have the Parallax 7400 55a converter, IMHO.... yes.
That was the OEM converter in our Classic, It's a 2 stage unit that ruined our Interstate deep cycles while still on the dealer lot.
I replaced it with a IOTA unit, when I switched to the Lifeline AGM's. It's a 3 stage converter that will keep the AGM's on a float charge when needed.
No worry leaving the AS plugged in for extended periods.
Still a good idea to check once in awhile just for peace-of-mind though.
Give Randy a call at Best Converter, he won't steer you wrong.
Old 11-18-2012, 08:49 AM   #3
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
Victoria , British Columbia
changing converter
Originally Posted by ROBERT CROSS View Post
Teton Stream,
Bob is that plug and play in other words can you just pull the old unit out and install yourself ?
LAWBC is offline   Reply With Quote
Old 11-18-2012, 09:00 AM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Yes, it is a simple remove and install job. Easy for the DIY'er. The recommendation to upgrade is not just because you changed to AGM batteries. It is a good upgrade for the deep cell batteries also. Pretty much removes the worry of overcharging and boiling your battery to death. Of course for peace of mind it's still advisable to check the water levels but the worry is gone. Some find the older convertors noisy and change them for that reason. I never noticed the noise and still don't with the upgrade done.
You won't be sorry.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-18-2012, 12:35 PM   #5
dznf0g's Avatar
Oswego , Illinois
X2...what Bob said. I have been very happy with mine.
-Rich-
Old 11-18-2012, 06:22 PM   #6
Thumbs up
LAWBC,
It was on our Classic....the install is under the front bed/couch.
It can be a little more difficult with other models depending on location.
Old 11-20-2012, 07:23 AM   #7
LAWBC's Avatar
Thank you all
Thanks Bob for the pics and info , I am going to do this upgrade , apart from checking the water level ,it sure beats running back and forth babysitting batteries !
I live on the west coast and it may get @ freezing maybe 2-3 weeks of the year .
Old 11-20-2012, 08:37 AM   #8
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Another recommendation for IOTA chargers. It was a pretty easy to retrofit into the existing space from the old converter and it quieter and better than the old converter.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Motorhomes, and Charging Batteries.... Keyair General Motorhome Topics 18 10-15-2011 08:21 AM
Bad Batteries? Nightwatch Electrical - Systems, Generators, Batteries & Solar 8 05-23-2011 01:58 PM
Controller wiring to bus bar or batteries? txstreamer Generators & Solar Power 4 04-26-2011 06:10 AM
