Old 05-16-2007, 06:47 PM   #1
martinez , California
charger / converter survey
If you were going to buy a new charger/converter, what features would you be looking for? What features would you like but can't find.
UJ
Uncle Jack is offline   Reply With Quote
Old 05-16-2007, 07:24 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
First thing to do is assess your 12VDC needs to determine what size converter to buy. If you have heavy usage, you should get a larger (75 amp +) converter.
3 stage charging IS A MUST HAVE to properly regulate the voltage charging your batteries. Temp control is always nice, as in the new parallax ParaMode 4400.
The resident Forum expert on all things converter is 68 Overlander. It's his business. I would suggest a look at his site: BestConverter - Inteli-Power, WFCO, Parallax, Inverters, Solar, Electrical Supplies and then a call to Randy. He WILL get you the proper set-up for your needs!
lewster is online now   Reply With Quote
Old 05-16-2007, 08:58 PM   #3
2005 22' International CCD
Woodland Park , Colorado
I second that. Randy definitely set me up right! jk
JK3500 is offline   Reply With Quote
Old 05-17-2007, 09:47 AM   #4
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I just ordered the 3 stage with temp control earlier in the week. Once I get it in and have used it some I will let you all know what my experience is. I found Randy to be helpful, not a hard sell in any way.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 05-17-2007, 12:17 PM   #5
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
I just purchased the Parallax 7300 for the vintage 1960 Trade Wind. More than needed but more is better! Now if I could only figure out how to connect the darn thing!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 05-17-2007, 02:30 PM   #6
wrepete's Avatar
1996 28' Excella
Geneseo , New York
UJ, I bought my charge/inverter/monitor setup from Randy a couple of years ago, based on his advice [along with a pair of Lifeline batteries], and the upgrade is worth every penny. We do a lot of camping in remote areas for extended periods, and this setup makes it easy to maintain electric level and know exactly when to run the generator, and for how long. Thanks to Randy. . .
Bud
1996 28ft Classic
2008 Silverado Duramax 2500HD
Hensley/BrakeSmart/EnKay
wrepete is offline   Reply With Quote
Old 05-17-2007, 11:53 PM   #7
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
I also bought a converter from Randy last month, a Parallax 4455 with temp control. It's a multi stage charger, and I believe it adjust to more then 3 settings as needed. My old univolt was still working, but I wanted to upgrade my batteries, and didn't want to chance the univolt on them. I saved enough space with getting rid of the univolt that I was able to go up to 3 batteries instead of 2. So far I'm happy with the setup, and the charger.
Charlie
Pacerized is offline   Reply With Quote
battery charger ALANSD Batteries, Univolts, Converters & Inverters 8 09-16-2007 06:52 PM
WBCCI Survey smily WBCCI Forum 33 11-13-2005 10:08 AM
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 07:52 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 09:45 AM
Converter box for into floor mount FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 10:49 PM
