Old 05-16-2016, 04:29 PM   #15
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by Robere View Post
So...I have a 2015 23' FC FB. Should I install a Progressive Dynamics PD4655, PD4645, or a PD4635 to replace the Parallax converter?
If the Parallax is a single stage converter what I have heard a multistage converter is always better on your batteries.
Old 05-16-2016, 04:58 PM   #16
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
Robere: Look on the inside cover of your converter. The last 2 digits signifies the amperage. I think you need a PD4655. You're Parallax is probably either a 7355 or a 8355.
glcmranger is offline   Reply With Quote
Old 05-16-2016, 05:01 PM   #17
2016 25' Flying Cloud
Holly Springs , Mississippi
So...Should I install a Progressive Dynamics PD4655, PD4645, or a PD4635 to replace the Parallax converter?
Replace your existing converter with one of the same amperage (PD4645 = 45A, etc.). That should be stated on the converter face plate, or in your owner materials.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 05-16-2016, 08:18 PM   #18
lewster's Avatar
Naples, FL , Hood River, OR
ANY existing converter on the market is still a compromise for properly charging Lifelines. A Magnum inverter with full temperature compensation is still BEST.
The 'normal' mode on the PD-4655 is 13.6VDC, which should equate to the absorption charge. Lifelines like this to be 14.2-14.4VDC @77 deg. F.
The other feature of an absorb charge is that the amperage tapers slowly as the battery fills and approaches 100% state of charge.
13.6VDC will work for those, but will significantly increase the required charge time to attain a full charge.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 05-16-2016, 08:29 PM   #19
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Originally Posted by glcmranger View Post
I just changed out the Parallax 7355 with the Progressive Dynamics 4655 on my new 25A sig 2 weeks after taking delivery on the TT. I wanted to ensure I didn't cook my new Lifeline AGM batteries. I ordered it from Best Converter. Very easy install.
Did you do the installation yourself?
Does the PD 4655 fit into the same opening as the Parallax 7355?
Where did you purchase the PD 4655 and your Lifeline AGM's?
Sorry for so many questions. I'm fairly good a mechanical things but never quite mastered the electrical field. Thanks!
Old 05-16-2016, 08:54 PM   #20
lewster's Avatar
Hans,
The PD-4655 replacement is a direct wire-for-wire conversion from the old Parallax unit. You should have no problems doing it yourself, as it fits into the exact same space as your OEM unit. Plan on 1-1.5 hours.
Old 05-16-2016, 09:30 PM   #21
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My poor 4 year old interstate's are still being charged by the original parallax and they will most likely last another 2-3 years and then they will be replaced with new interstate 's......
Old 05-16-2016, 09:52 PM   #22
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I am not a fan of AGM batteries. I don't really see the value in paying big bucks for batteries that will last about as long as flooded cell batteries that cost 1/3 the price, let alone paying more money for a converter that will work well with them.
When I ruin a set of flooded cell batteries by inadvertently and absent mindedly discharging them it does not hurt so bad...
(I think that flooded cell batteries are more tolerant of abuse than AGMs)
FWIW, #JustSayin
Superat stultitia.
Old 05-17-2016, 05:46 AM   #23
GLCMRANGER - Sue
Hans627: I PM'ed you but since I'm computer challenged, it might not have posted. Let me know if you didn't get the PMs.
Old 05-17-2016, 07:04 PM   #24
Hans627's Avatar
I got your PM's but just haven't had time to read and understand. Thanks for taking the time to share your experience!
Old 05-22-2016, 08:50 PM   #25
Hans627's Avatar
I just ordered a PD-4655 to replace my Parallax. While fairly competent with most mechanical things, I'm a bit challenged with electrical projects. But I'm going to give it a try and have several people who have offered to assist if necessary.
Thanks for everyone's input!
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
Charger/Converter wiring question BigRedExpres Batteries, Univolts, Converters & Inverters 0 07-15-2013 07:49 PM
Converter/Charger Question Tartimisi Batteries, Univolts, Converters & Inverters 5 02-25-2013 02:53 PM
Converter/battery charger ARGONUT Batteries, Univolts, Converters & Inverters 0 11-23-2003 04:28 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
