Old 04-19-2012, 09:13 AM   #1
2004 16' International CCD
Orem , Utah
Charge wire on 7-pin, what demands does AS need and how does this charge
I just installed new jacketed 2wire 2 12 one blue and one black wire. Both 12 gauge. Did trailer supply give me bougus wire, I asked for 10gauge 1.70 foot could not find any. Say's they wire all there installed with this 2 12. Should I rip all this out and return it. Right now it is connected to 30amp breaker problem 12gauge is only rated up to 20amps.
starcraft is offline   Reply With Quote
Old 04-19-2012, 09:21 AM   #2
1974 Argosy 20
Kooskia , Idaho
Due to the length and resistance of all the wire from the front of the TV to the batteries on the AS, you will seldom get a charge of more than 10 to 12 amps max. Six to nine amps is probably more typical. So, if it were mine, I would not worry about it.
Old 04-19-2012, 10:31 AM   #3
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
charging from the TV
Check out the following: http://www.airforums.com/forums/f449...s-78925-2.html panel #21.
the 7 pin connector is woefully undersized to recharge the AS batts from your Tow Vehicle.
wmarsha is offline   Reply With Quote
Old 04-19-2012, 10:48 AM   #4
dznf0g's Avatar
Oswego , Illinois
That being said, I have never had an issue replenishing a pair of group 29 batteries, 50% depleated during an 8 - 10 hour....say 400 mile drive.
-Rich-
Old 04-19-2012, 02:19 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
I just got a roll of 10 gauge marine duplex wire from a surplus place. It's out there, but you have to look. Copper prices are high so it's going to cost you. Trailer places usually don't have anything larger than 12 gauge.
They lack both imagination and experience.
Depends what you want. Larger wire will give you more charging. I have 8 gauge in my suburban, and 10 gauge in my pickup.
The idea that 12 gauge wire is suitable only for up to 20 amps is based on U.S. residential electrical codes which were based on 1920s insulation technology using asbestos-reinforced rubber.
The practical capacity in automotive and trailer wiring depends on a bunch of things, among them the heat the insulation can withstand and whether the location where the wire is installed is cool or hot. It is not unusual to fuse 12 gauge automotive circuits at 30 amps. In fact, in some circumstances, higher ratings are used.
Old 04-19-2012, 09:06 PM   #6
richinny's Avatar
2011 34' Classic
you might find that buying a set of jumper cables is cheaper than buying just the wire.
Ricky
Old 04-20-2012, 07:38 AM   #7
Orem , Utah
How does TV battery charge up AS
I hope these are wired directly battery to battery. Stopped by Home Depot and looked at there wire. They do have 8 Gauge wire in bulk section priced 65cents foot. How would this type wire do on automotive. Less strands than typical wire. Also for single axle trailer brakes would 12 gauge be large enough for brake controller. 17ft run
Old 04-20-2012, 07:51 AM   #8
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
Becuase of the 'skin effect' stranded wire offers less resistance (thus more current flow) than a single conductor wire of the same cross section....I think if youll be just fine with either 8 or 10.
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 04-20-2012, 07:57 AM   #9
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I agree, however don't expect a tremendous charge rate. If you see anything over 5 amps or so consider it a bonus.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-20-2012, 08:02 AM   #10
Orem , Utah
I found this wire $10bucks
Cadence 8 gauge 20feet for amp installs
CADENCE 8 GAUGE 20 FEET RED AMP POWER/GROUND WIRE (613815568254) | eBay
Old 04-20-2012, 08:38 AM   #11
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
Yep...5A may be about all you get...maybe a bit more...i wonder if it would be much better if the batteries were relocated to the front of the trailer...? eliminating 20'+ of wire....
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
