Old 04-13-2011, 08:13 AM   #1
AirHome's Avatar
1973 29' Ambassador
San Diego , California
Charge line breaker stuck open
I found what I believe is a charge line breaker at the umbilical entrance in the front of my 1973 International. It was stuck open and I couldn't get the vehicle charge into the trailer until I bypassed this.
Do I need to have a circuit breaker between tow vehicle battery and the trailer (blue wire)?
I attached a picture in case I am wrong, and this is something different.
Name:	Vehicle Battery Charge line Breaker.jpg
AIR HOME - 73' Ambassador International
Remodel blog: Air Home
Work: http://www.emaxaction.com/
AirHome is offline   Reply With Quote
Old 04-13-2011, 08:20 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The chances are that if your TV is a factory wired that there is a fuse in the line from the vehicle.. A replacement breaker for the trailer should be available at any auto parts and probably less than $5.00.. I would travel with it bypassed if need be but would replace it at a convenient time
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-13-2011, 08:30 AM   #3
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
You need a circuit breaker. They are available at Auto parts or RV parts stores. It appears to be one that self resets.
Michelle TAC MT-0
Sarah, Snowball
Old 04-13-2011, 10:18 AM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
You need the breaker.
Without the breaker, if the 7 way or umbilical shorts out, the umbilical cord could catch on fire and ignite whatever is around it. That can happen if the cord gets pinched somewhere during a turn or in a collision.
Gas line to water heater '73 International cuyd Water Heaters, Filters & Pumps 13 04-04-2011 09:47 AM
Zip Dee Z-lock lever is stuck aname4me Awnings 4 03-17-2011 06:13 AM
A Frame end open Sphere Guy Repairing/Replacing Floor &/or Frame 4 02-27-2011 02:48 PM
What would cause all the joints to open? robwok Plumbing - Systems & Fixtures 10 02-24-2011 04:06 PM
Holding the door open, when stopped Maggiefoss Doors & Locks 5 02-13-2011 12:35 AM
