Old 09-10-2009, 06:45 AM   #1
rye
1968 28' Ambassador
Clarks Grove , Minnesota
change to a univolt from a convertor
I have a 68 ambassador land yacht international and the covertor charger hums pretty loud. My question is I do have a Univolt system out of a 72 land yacht but I have noticed it has several 14 gauge and bigger wires coming out of it while the convertor chager in the trailer don't have those wires, how do I hook it up? Are the wires because the fuse block is internal on the univolt and external on the convertor charger in the trailer?
rye is offline   Reply With Quote
Old 09-10-2009, 07:22 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums. The wires are probably larger because the Univolt has a larger capacity, along with the possible realization the wires should be bigger in your trailer.
It would be a good idea to get rid of both Univolts, and get a new one. They're not that expensive, are quieter (the 1970's Univolt still hums), more reliable, and treat your trailer's battery better.
Old 09-10-2009, 09:14 AM   #3
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
I agree get rid of both and go with an intelipower (spelling on a blackberry)
With acharge wizard. They are easy to install, quiet, and won't over charge your battery.
I forget where I bought mine I think it was bestconverters.com
Good luck
nick6930 is offline   Reply With Quote
Change Univolt If It's Working ???? Clyde-2 Batteries, Univolts, Converters & Inverters 23 09-30-2009 07:54 AM
Change-out Univolt for WFCO Bulldogger Batteries, Univolts, Converters & Inverters 10 11-09-2007 08:11 PM
charge convertor 31airstream Batteries, Univolts, Converters & Inverters 2 06-12-2007 06:03 PM
power convertor ifly4cal Electrical - Systems, Generators, Batteries & Solar 4 12-07-2005 08:40 AM
Convertor question - 2005 Classic Pappy 2001 - 2005 Classic 2 05-30-2005 09:42 PM
