Old 06-23-2010, 09:27 AM   #1
stephenh2's Avatar
Tyler , Texas
Change out of Univolt
Well I pretty much completed the upgrade to my new Inteli-Power 7200 yesterday. I also took the time to repair the battery box, which was in poor shape due to the entire weight of the old Univolt resting on top of it with support only on one end.
The door to the battery box still doesn't close as well as I would like, partially due to the fact that the PO replaced the latch bar with something completely inadequate. He put a flimsy metal bar there that bends with only a moderate amount of pressure applied to it. I need to find a replacement for the bar, so if anyone has one laying around, I would be glad to make a deal for it.
Photos of the upgrade:
I closed off the "new" converter compartment with 1/4" plywood, leaving ample air flow top and bottom. The framework for the opening stiffened up the panel sufficiently for me to feel good about the horizontal mounting arrangement.
Stephen
Home again in Tyler, Texas
Please visit any time!
stephenh2 is offline   Reply With Quote
Old 06-23-2010, 12:13 PM   #2
Stephen
Looks great.
Old 06-23-2010, 12:48 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Don't throw away the fuse block inside the Univolt. It has the current measuring shunt on it.
Zep
Old 06-23-2010, 01:53 PM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Zep,
What is the current measuring shunt still needed for? Isn't there on integral with the Intelli-Power and similar systems? (Please pardon my ignorance, I understand DC systems and T/R's, but the Airstream setup is new/unfamiliar to me.)
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 06-23-2010, 02:02 PM   #5
1975 31' Sovereign
1977 23' Safari
Originally Posted by Aviator View Post
...What is the current measuring shunt still needed for? Isn't there on integral with the Intelli-Power and similar systems? ...
The IntelliPower has auto current limiting and shutdown. It does not have an output that tells you what the current is, real time.
The shunt is an approximately 0.001 ohm resistor. You put it in the battery's negative (ground lead). In the ground lead, both of the sensing wires are never more than 50 millivolts above ground--it's a nice safety approach. You will find three small gauge wires back where the Univolt was and you now don't know what they did. One of them was tied directly to the positive side of the batter and reported total battery voltage. The other two were attached across the shunt and reported amps in millivolts/amp (one millivolt equalled one amp). The 1975 and later models had a mechanical voltmeter and millivoltmeter in the control panel, but they were inaccurate, to say the least. Sort of a green-yellow-red scale. See an alternative here. If you read the whole thread, for $50 you get an electrical engineering degree.
Zep
Old 06-23-2010, 03:51 PM   #6
2xS
2xS's Avatar
1971 31' Sovereign
San Diego , California
I need to find a replacement for the bar, so if anyone has one laying around...
I used an 2" x 3/8" steel plate cut to length for this job; I drilled and riveted a new piano hinge to the door and to the plate, then I riveted the plate to the trailer. It's looks lovely and is solid.
Getting rid of that Univolt was one of the first things I did; mine was installed under the bathtub that was disintegrating!
When it comes down to it:
Univolt = any fuse block + any 12V power supply/charger
@Zep - You assume the control panel still functions or that someone (without an electronics degree) could fix it!
Lasciate ogne speranza, voi ch'intrate
2xS is offline   Reply With Quote
Old 06-23-2010, 06:14 PM   #7
1975 31' Sovereign
1977 23' Safari
Originally Posted by 2xS View Post
...Zep - You assume the control panel still functions or that someone (without an electronics degree) could fix it!
Ah, ha! Everyone could have a working control panel (or at least working tank level monitors) if they got on the band wagon and made a group purchase of the circuit board and panel linked above.
Zep
Old 06-23-2010, 07:02 PM   #8
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
Thanks, Zep.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 06-23-2010, 07:55 PM   #9
2xS
2xS's Avatar
1971 31' Sovereign
Zep,
I had been eying your offer on that for a while, as well as your research on the replacement. I would have taken you up on it if it wasn't for some fancy bells and whistles I would like to integrate like ALL digital indoor/outdoor temperature, propane tank levels, battery voltage and ammeter data from the 4 main branch circuits; I'd also like to display the charge rates of my solar panels and wind turbine (those circuits haven't been ran to the control panel yet though, and I don't know if I want to)... I'm also going to attempt to give the panel a Star Trek like feel by hilighting a wire-frame-Airstream model with the data displayed around it; the panel is a piece of Plexiglas with a clear adhesive printable vinyl sheet blacked out in the areas that I don't want light to shine through...
Besides polishing this thing, the control panel is the last real project to tackle, but I'm still in the wake of enjoying the fruits of my 10 grueling month, +60 hours a week restoration. I've had big plans for that control panel from the start... because I do happen to have an electrical engineering degree
PS I will be utilizing your R2R comparator ratios and relative tank level-resistance data as a baseline though, and THANKS for that!
Old 06-23-2010, 09:23 PM   #10
stephenh2's Avatar
Tyler , Texas
Thanks for the input.
Zep, I did read the whole thread a few days ago. Its still quite a bit over my head... so I think I'll keep my 50 bucks. I don't really have time right now to take on an upgrade like yours. I'm going to be hitting the road with my rig next Thursday.
What do I need to save off of the old Univolt's fuse panel, the whole fuse panel or just the shunt plate? How do I get the plate off, is it riveted onto the fuse panel? (I see the four rivets that fasten the fuse panel to the Univolt) Then, when I get it off, can I connect it to my fuse box with a wire to each end of it and then connected across one of the fused circuits, then just plug my old wires back onto it?
Any other parts worth salvaging on the Univolt?
thanks,
Stephen
Old 06-24-2010, 08:00 AM   #11
1975 31' Sovereign
1977 23' Safari
...What do I need to save off of the old Univolt's fuse panel, the whole fuse panel or just the shunt plate? How do I get the plate off, is it riveted onto the fuse panel? ...
Nothing worth salvaging except the shunt. You can make a new shunt out of 11" of #8 stranded copper wire and two medium electrical cleats, it's not a disaster if you don't save it. If you want a high amp 12V power supply for your shop, sometimes and old Univolt can be used for testing pumps and jacks, etc., but that's the only use I can think of (unless you're building a foam airplane and you need a hotwire cutter).
I recommend against using the Univolt fuse block. Get a new 12V fuse block that uses the mdoern flat automotive fuses.
Zep
Old 06-24-2010, 10:35 PM   #12
stephenh2's Avatar
Tyler , Texas
Zep,
My shop is on my back right at the moment. Don't think I want to carry a Univolt around with me. I'll take a shot at removing the shunt and carry it on down the road for awhile. The Blue Monster will have to stay in Reno, in a dumpster or otherwise. If I can't figure out how to set it up, I can do without a meter for awhile.
Oh, I did replace the fuse block with a new one. I'm very happy with it and highly recommend the upgrade.
Stephen
Old 09-30-2010, 02:38 PM   #13
Newberry , Florida
In your third photo...the front of the old univolt, there are three wires. A red and black that both have a 90 degree push on type connector that are attached to a flat steel plate "AMMETER BLACK" and "AMMETER RED". And the third is a single gray wire on the bottom right corner with a spade style connector. What are these three wires for and what do you do with them on a univolt replacement. I don't see them on your after photos? Any guidance on this would be great, I'm in the middle of a replacement right now.
Overlander is offline   Reply With Quote
Old 10-01-2010, 07:30 AM   #14
stephenh2's Avatar
Tyler , Texas
The Push on red and black wires are for the meter in your control center. I just left mine loose since there is no shunt for an ammeter on the new converter. I removed my fuse panel and saved it with the old shunt intact in case I decide I want to try and reuse it.
I THINK the gray wire is for the "Shore Power connected" indicator light in your control panel. I also left this loose. I just plug something in to and A/C outlet in the trailer if I want to know if I have 110v service connected.
I just got my system to where it is usable and put off the 'extras' until later. I may ore may not decide to connect and use those circuits later on. Best of luck to you.
Stephen
Change Univolt If It's Working ???? Clyde-2 Batteries, Univolts, Converters & Inverters 23 09-30-2009 07:54 AM
change to a univolt from a convertor rye Batteries, Univolts, Converters & Inverters 2 09-10-2009 09:14 AM
Change$$$$ Pop Rivet On The Road... 7 07-31-2009 03:31 PM
Change-out Univolt for WFCO Bulldogger Batteries, Univolts, Converters & Inverters 10 11-09-2007 08:11 PM
Can I Change My Name? Rivetedude Forum Admin, News and Member Account Info 26 07-01-2005 12:43 PM
