Old 12-06-2008, 04:40 PM   #1
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Change From Group 24 to 27?
I currently have 2 Group 24 batteries on my 84 31' Excella that are nearly 6 years old, and on their last leg. When I bought these was right after I purchased the trailer, and I just put back the size that was already there. I didn't know to even consider the size change.
It appears I have room in the boxes to go up to Group 27 batteries from the Group 24 size.
Is there ANY reason not to buy the bigger battery?
Thanks in advance for the input.
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 12-06-2008, 04:50 PM   #2
New Borockton , Alabama
Images: 21
No reason if they will fit. Sometimes bang for the buck is a concern. I've seen some brands group 31s only 5 more amp hours then the 27s yet the price jump is significant.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 12-06-2008, 06:36 PM   #3
Images: 59
I think you need to price them. At Sam's Club the Group 27 are slightly more expensive then the Group 24. The difference is about $10 per battery, for a 10ah difference in capacity.
At $1.00 per amp-hr you could stay with the smaller ones if total capacity isn't an issue.
Old 12-06-2008, 07:42 PM   #4
pyanke's Avatar
1985 25' Sovereign
St Cloud , Minnesota
I switched to the smaller batteries in my Sovereign a couple of years ago. It makes it a lot easier to take them out for the winter and put them back in when spring rolls around.
Pete
WBCCI #7528
MN Unit
pyanke is offline   Reply With Quote
Old 12-06-2008, 07:43 PM   #5
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I sized my battery box to hold two group 27's and promptly put a spacer in and filled it with two group 24's. I didn't want to lift or carry the extra weight. Arthritis makes every pound count. I haven't missed the extra capacity yet.
Sam
samb is offline   Reply With Quote
Old 12-06-2008, 10:14 PM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Anyone know offhand if I can fit grp 27s in the factory 2004 battery box in the "A" frame?
Since letting mine die outright a few times, this spring, I have to replace them, and since I boondock a lot more than I have electric hookups, if I can get a bit more juice with the 27s (and they would fit in the factory box), I'd go that route, since upgrading to the 3 stage charging eliminates the cooking issues.
Old 12-13-2008, 12:07 PM   #7
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I went with the group 27s yesterday.
Price difference was $6 a battery over the 24s.
The weight difference isn't that much.
David
TAC # TX-18
AIR # 410
Old 12-13-2008, 12:29 PM   #8
Images: 59
I have to change my previous posting. I also just bought two group 27s at Sams Club an hour ago. When I rechecked the prices they weren't $10 difference, more like the $6 you noted. Also, when you factor in the core charge, the price difference is neglible.
Old 12-13-2008, 12:40 PM   #9
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I changed batteries this past spring. The PO let them discharge /freeze and bust. I replace them with Group 27 Marine from AUTOZONE. I don't off hand recall the price. I just replaced the Grp 27's that were there.We ran them this season without a problem. Grp 27's just fit in the boxes of the Overlander.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
New to the group -1965 65trotter 1965 - 1969 Globetrotter 29 11-16-2008 12:34 AM
New to group debbiesull Member Introductions 4 11-02-2007 04:12 PM
Hello Group Heirstreamer Member Introductions 4 01-22-2007 05:55 PM
New to the group alhoos3228 Member Introductions 1 06-15-2006 12:28 PM
New to the group! Streamin 65 Member Introductions 10 03-16-2006 04:18 AM
