Old 11-30-2014, 11:56 AM   #1
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Change from group 24 batteries to Trojan T105s
Good day all. To anyone that has made the change from standard 12v group 24
batts to the trojan T105's. What terminals on the battery did you go with and did you change the standard auto cable terminals to lug type? The trojan web page shows an auto type terminal with a bolt that extends out the middle of it but will the auto cable terminal fit flush so the bolt can be used as a connection between the two batteries? Any advice would be welcome thank you all. Rand
grizbear is offline   Reply With Quote
Old 11-30-2014, 01:58 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Trojan T105 batteries have four different terminal types: Embedded high profile, embedded low profile, embedded automotive, and embedded universal. Regular automotive-style clamp-on connections will work on everything but the embedded low profile. Screw-on connections will work on the embedded low profile and embedded high profile. As long as you specify the right post type, you'll do fine.
The biggest difference is T105s are 6v batteries, so you have to go from parallel to series connection to get 12v out of them.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-30-2014, 03:06 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Trojans are taller and wider than group 24, check your space carefully, if they will fit you will get more amp hours and they could last twice as long.
Old 11-30-2014, 05:00 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
You will need a 1-1/2" spacer between the top of the battery box and the hinged cover to be able to place T-105's (or Lifeline GPL-4CT) golf cart batteries inside.
Many have done this mod by removing the hinged cover, adding the spacer made of suitable material (I generally have an aluminum 'picture frame' made at a local metal shop) with rivets from under the top of the old box, and then re-positioning the hinged cover and re-riveting it into place.
Old 11-30-2014, 10:28 PM   #5
1974 Argosy 20
Kooskia , Idaho
They are taler, but not wider than the group 24's. Their base footprint is virtually identical.
Old 12-01-2014, 08:03 AM   #6
grizbear's Avatar
2004 25' Safari
Crestview , Florida
T105 Batt change
Thanks, I have already raised the top of the batt. box by 1 7/8". I was hoping not to have to change out the standard auto type terminals and be able to use lug type connections between the two batteries. correct me if I'm wrong but I will connect neg post of batt. (1) to + post of batt. (2) and (+) trailer cable to (+)post of batt (1) and neg trailer cable to neg post batt, (2) and trailer jack to (+) post batt one. Does this sound right?
Old 12-01-2014, 08:23 AM   #7
lewster's Avatar
Sounds right. Auto-type screw-in terminals are available for batteries that have threaded connections that will allow the use of Airstream's OEM terminals.
From my experience, I replace any automotive type terminals with eyelet lug ends, as I have found them to be a much more solid connection.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 12-01-2014, 04:11 PM   #8
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Thanks to all.
Group 24 to Group 27 Batteries in my 27ft International BoldAdventure Batteries, Univolts, Converters & Inverters 8 02-26-2015 07:52 PM
Group 24 to Group 27 handn Batteries, Univolts, Converters & Inverters 2 06-07-2014 06:42 PM
Trojan warning Ganglin Off Topic Forum 2 04-24-2010 09:46 PM
Help-Group 31S vs Group 27 Battery Question trevisgardne Batteries, Univolts, Converters & Inverters 4 06-10-2009 08:32 AM
