Old 02-23-2010, 08:12 AM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Central location for battery and converter
Thinking of centrally locating bat.,converter,breaker panel etc.under twin bed behind wheel well.Anyone have a pic, or has seen a post with a clean install
of centrally located electrics?
bwaysteve is offline   Reply With Quote
Old 02-23-2010, 08:26 AM   #2
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
The Award 23 we had before the Airstream featured such an arrangement. The batteries were under the passenger side twin bed, near the rear of the trailer and accessed from the outside, behind an access door. The batteries were on a pull out tray so you could easily service them. The converter & panel were under the forward end of the driver side twin. Only issues were, heat from the converter in summer and the noise from the converter vent fan when sleeping.
So Long!
Bob Thompson is offline   Reply With Quote
Old 02-23-2010, 08:39 AM   #3
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
check this out:
Battery Replacement | Used Airstream Trailers
Kevin does great work but video editing takes removes some of the time/money factor....your mileage WILL vary ;-)
fotochop is offline   Reply With Quote
Old 02-23-2010, 08:57 AM   #4
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Here are a few more things to look at. http://www.vintagetrailersupply.com/...ingdiagram.jpg, http://www.airforums.com/forums/f226...tml#post760297 and http://www.airforums.com/forums/f449...tml#post713684. BTW, You're doing great. Keep it going.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 02-27-2010, 10:58 AM   #5
New Borockton , Alabama
Images: 21
I think that is a great idea. Having the weight over the axels and a central location makes sense. I've always scratched my head on some designs that run 20+ feet of DC wire. It results in voltage drop that directly affects the converter operation in many cases. Simply increasing the wire size can help but often not feasable to run it.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 02-27-2010, 11:41 AM   #6
alclad's Avatar
1961 16' Bambi
Wilmington , DE
Images: 46
I replaced the 12v mounted on the tongue with 2 6v lifelines. one under the gaucho the other in the closet, both over the axle on our 61 bambi. works good. ran the cables in electrical conduit that goes through the floor then attached to the axle. 2" pvc glued sweep bends come through the floor next to each battery. best converter--i.e. randy fixed me up with the electrics. the 61 is standing tall! i'll try for some pictures tomorrow as it is, i think, a clean installation.
alclad is offline   Reply With Quote
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
converter / battery charger somedaysoon Batteries, Univolts, Converters & Inverters 3 12-28-2008 10:56 AM
Battery location? prairieschooner Batteries, Univolts, Converters & Inverters 12 10-04-2006 08:19 PM
Battery Location & Hook Up achip Batteries, Univolts, Converters & Inverters 0 06-28-2006 08:12 AM
battery location Dave&Heide Electrical - Systems, Generators, Batteries & Solar 4 09-15-2002 06:32 PM
