Old 05-29-2016, 10:08 AM   #1
Santa Rosa , California
can't hook up 120V
We just got an '83 310. When I hook up 120 from the garage, the GFI in the garage trips. This happens even if all the breakers are open. Anyone heard of this. I have looked for a switch to be sure to be one 120v and not generator, no luck. Thanks justjim707
justjim707 is offline   Reply With Quote
Old 05-29-2016, 12:04 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Yes, you cannot hook up lots of RV's to a GFI protected circuit. I've tried it and I'm not sure why. I suspect there is a radio frequency filter or some high resistance path to ground in the RV tripping the GFI.
Plug it into a non-GFI source and it will most likely work.
Doug and Cheryl
Old 05-29-2016, 12:15 PM   #3
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Are you using a 30a to 120a adapter, "dog bone". GFIs can be kinda tricky. Might be the adapter youre using, could be an old worn out GFI outlet, could be a ground issue in your panel, could be a number of things. Whatever you do, start with the easiest first. Assuming youre using a 30amp to 120amp adapter, have you plugged just the adapter into the outlet without your power cord attached? Check your grounds on both ends of your power cord. Check you plug on the power cord. Thats where I would start.
Mike
mayco is offline   Reply With Quote
Old 05-29-2016, 01:17 PM   #4
2015 30' Classic
Pleasanton , California
GFI outlets look for an imbalance hot and neutral line current. You might have a fault or an unintentional leakage path in one of your 120 V circuits in the trailer. One way to help diagnose this is the disconnect all your 120 V breakers in your trailer and then connect your trailer to the GFI outlet. Connect back the breakers one by one until you identify which circuit contains the fault.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 05-29-2016, 01:40 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
OP said it happens with all breakers open.
Some things to check:
Hot to neutral reversal at GFCI is possible. Get an outlet checker and plug it into GFCI. It may be wired wrong. Problem would not show up with corded items.
If OK, disconnect power cable from 310 and try with just the cable.
If OK, check cable with ohmmeter for proper connections, hot to hot, etc.
If still OK, check 310 with ohmmeter to make sure that hot and neutral or neutral and ground are not reversed.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-29-2016, 02:39 PM   #6
1973 31' Sovereign
Middletown , California
You may need to get a digital ohm meter and start poking around. GFI's trip when there is a very tiny current leak to ground, they monitor the current going through the hot wire and if the same amount does not come back through the neutral wire they are supposed to trip. The amount of current that can trip a GFI is very tiny, it could be that your power cord is damp inside or that the insulation in the walls is damp. Some GFI's are less sensitive than others, you might get lucky by changing out the GFI. I would check for a high resistance path from the hot and neutral wires to ground using a ohm meter. GFI's are not a totally reliable device, they are mass produced after all; I've seen trailers with live skins even though they are plugged into one. I've also removed GFI's more than once in order to make a refrigerator with damp insulation work. It never hurts to check out things with a good Volt/Ohm meter to be sure what the situation is.
ijustlee is offline   Reply With Quote
Old 05-30-2016, 01:21 PM   #7
Thumbs up fixed
Thanks to all, I just connected the 120v to a non GFI protected outlet and it worked. On to the next project-after a nap. Jim
Old 05-30-2016, 02:35 PM   #8
2014 27' Flying Cloud
Stowe , Vermont
I had this happen regularly hooking up to my garage too (with GFI). My cable can reach my front porch outlet (with GFI too) and I have had no problem.
VT Wanderer is offline   Reply With Quote
My Hook Things Won't Hook Sbb Rock Guards, Segment & Window Protectors 2 04-12-2015 06:16 PM
Can a 30AMP 240v provide 2 30AMP 120v?? VeggieBullet Electrical - Systems, Generators, Batteries & Solar 17 05-29-2013 09:28 PM
Where can I find replacement hook latches? mello mike Rock Guards, Segment & Window Protectors 2 03-26-2011 08:30 PM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
Can you hook up a disposable propane cylinder? bhayden LP Gas, Piping, Tanks & Regulators 5 06-16-2006 09:10 PM
