Old 01-21-2010, 01:53 PM   #1
Holland's Avatar
1971 27' Overlander
1963 22' Safari
Venlo
Can't find Univolt
Hello,
I can't find the univolt in my 1963 safari 22 ft, is there no univolt ? or is it hidden very well ? I would like to convert the electricity to europian standard 220 volt.
And where would the fuses be if there are any ?
I am a total bum when it comes to electricity..... so your help is welcome !
Holland is offline   Reply With Quote
Old 01-21-2010, 01:58 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Originally Posted by Holland View Post
Hello,
You shouldn't have a univolt on a 1963.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-21-2010, 02:11 PM   #3
Holland's Avatar
1971 27' Overlander
1963 22' Safari
Venlo
Oke, How is de battery charged then ?
Old 01-21-2010, 03:17 PM   #4
1967 22' Safari
1960 Caravel
Images: 8
Off of the auto that is pulling it or a battery charger. What do you have in the Airstream that runs off 12 VDC? It shouldn't be much unless it has been changed somewhere back in time by a previous owner.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-21-2010, 04:30 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
I asked this question the other day about a 62. The answer came back that the 62s did not have a charging system in the trailer but rather just charged off the TV while towing.
You may have the same condition. Look at the wires going to the battery. If they are small # 12 wires you more than likely do not have a Univolt. If they are larger wires say # 8 or larger than the trailer may have had one originally.
If you install a converter make sure you size the wires to the output of the converter. A 40 amp converter would require at least # 8 wire going from the converter to the battery.
2004 Excursion 4x4
Old 02-04-2010, 04:16 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you had a Univolt, you would probably hear it humming..
Old 02-04-2010, 07:07 PM   #7
2008 16' Safari
Destrehan , Louisiana
Or smell it burning.
dlb435 is offline   Reply With Quote
Old 02-04-2010, 07:09 PM   #8
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
A 63 has a vent fan and a overhead fan that will have two position switches so they can run off 12 or 110 volt. They will have dual wall sconces and dual bulbs in the overhead lights so you can run off either 110 or 12 volt. Put in a converter or carry a battery charge for more versatility.
Old 02-04-2010, 07:11 PM   #9
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Yes, '63 models didn't have anything onboard to charge the battery, it was done through the charge line from the tow vehicle. I installed a late-model converter in our '63 near the battery compartment, and left the plug where I could unplug it if needed. If you don't want to invest in a converter, you can pick up an inexpensive battery charger to keep the battery charged.
Can Anybody find this ?? augier Doors & Locks 4 02-21-2009 08:51 AM
This may have been ask before,But if so i couldn't find it Angel73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 03-11-2007 11:52 PM
Does anyone know where to find................ parrishw Cabinets, Counter Tops & Furnishings 1 05-23-2006 09:24 AM
New Find Chris C 1960 - 1964 Overlander 14 11-12-2005 07:00 PM
Can Not Find Leak Help! Rennegarbe1 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 05-12-2003 04:08 PM
