Can you plug into shore power and run the 110 outlets without having a battery in the AS. Will this hurt the intellipower? Don't want to burn anything up.
Common Sense
You can do it and even power the intellipower. The only thing you need to be careful of is making sure the battery wires, the ones that attach to the battery, are not shorting to each other. That way, your 12 volt lights will work.
