Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 03-16-2017, 07:41 AM   #101
Electronic Controls OEM
Micro-Air's Avatar
Allentown , New Jersey
EasyStart 364 Installation Options for Dometic Penguin II
Given dblee1950's questions and Turk123's pending installation, I figured I should try and summarize the 2 methods of installing the EasyStart 364 into the Dometic Penguin II.
EasyStart 364 in black enclosure: Myself and others have successfully installed this into the electric box. I made a detailed post on this with a PDF document at this link. Black enclosure EasyStart 364s are almost gone though, so soon everyone will be getting the IP65 model. There are still some available though, and I will have an exact count shortly.
EasyStart 364 in the IP65 enclosure: I'd like Turk123s opinion on this since I think he'll still be the first to do it. Rather than run the harness through the existing hole in the plastic condenser airbox enclosure, I'm thinking if we cut a new hole where shown (#1), lie the EasyStart on its side and route the harness through this hole (#2), it should reach the electric box inside of which the connections can then be made with standard crimp terminals (#4). (Then, there will be no need for the epoxy type of terminals.) Then, all you have to do is make the new hole air tight with some duct seal putty (#3). Let me know what you think, Turk123.
Name:	Dometic Penguin II Black Enclosure ES364 Installation.jpg
ID:	281531   Click image for larger version
Name:	Dometic Penguin II IP65 ES364 Installation.jpg
Technical Support
Micro-Air, Inc.
Micro-Air is offline   Reply With Quote
Old 03-16-2017, 02:47 PM   #102
2014 25' Flying Cloud
Mount Dora , stevenwilliams
I use the Yamaha 2000 with the Easy Start on my 2014 Airstream 25FB. I hooked up the Easy Start my self, and if you know how to read a wiring diagram, you can too (4 wires). I found space within the large, plastic A/C roof cover using the existing Easy Start wires. Call me if you have any questions. Steve 352/383-3282
sburrw is offline   Reply With Quote
Old 03-16-2017, 08:08 PM   #103
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Do you have the 15,000 BTU low profile Dometic Penguin on your trailer?
kscherzi is offline   Reply With Quote
Old 03-16-2017, 10:06 PM   #104
2016 30' International
redondo beach , California
For what its worth, Colonial Airstream in New Jersey, even though they have no previous experience, offered to install the MicroAir devices in our new 2016 International before we picked it up. However they warned us that this would void the warranty and recommended to wait until the warranty expired.
I have to make a decision. Do I use our new trailer as a learning experience for the techs at Colonial? On the positive side it would be the most convenient installation and great to have both ACs powered by our generator set.
My second option is AAP in Virginia.
Or just wait for the Turk123 to document his experience.
RC
mythbuster88 is offline   Reply With Quote
Old 03-16-2017, 10:35 PM   #105
Journeyman
2016 25' International
Amherst , Massachusetts
RC
I would totally let them do it. They have no interest in leaving you unhappy, and the install is simple enough that amateurs should be able to do it...
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 03-17-2017, 04:23 PM   #106
2022 Atlas
Homosassa , Florida
I would not void the warranty.
Tater is offline   Reply With Quote
Old 03-17-2017, 04:52 PM   #107
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I believe they wanted me to turn the easy start so the exiting cable is on the bottom to avoid and water getting in through that gland. If you do that the cable will not reach the electrical box. It is still pretty inexpensive to install in the airbox, so that is where I will go. Maybe Microair will supply a penguin II option that either has a longer cable, or includes a few connectors and heat shrink tube. This is not rocket science and should not intimidate anyone. Hell, I had more difficulty learning to dump the black water
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 03-17-2017, 05:03 PM   #108
The Colonel's Avatar
2017 25' Flying Cloud
Florence , Alabama
Turk, are you leaving your configuration as you installed it?
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 03-17-2017, 06:48 PM   #109
Micro-Air's Avatar
Earlier this week, we ordered a new Dometic Penguin II at Micro-Air for further testing. If by when we receive it, the weather hasn't allowed Turk to have completed his installation, we'll do an install of the IP65 EasyStart 364 per my proposed recipe, take detailed photos, and post them here. I do not know the estimated delivery date.
Technical Support
Micro-Air, Inc.
Old 03-17-2017, 11:23 PM   #110
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
Looking forward to your report, Matteo. I'm also working with my local Airstream dealer, getting them jazzed about installing the EasyStart on Rocinante and then doing the same later for other customers who express an interest. I know it's not that hard to do, just don't want to spend time on my roof if I don't have to. I'd also be happy to be their first install, as I have confidence in them.
Old 03-18-2017, 06:19 AM   #111
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Dang. I'll renew my offer to bring the trailer to your place (In nj) to play with. I have the penguin ii I believe (2014 airstream). Can also bring a Yamaha 2000...
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 03-18-2017, 12:45 PM   #112
Micro-Air's Avatar
Outstanding! Many thanks. Certainly have your dealer contact me if they have any questions.
Thank you again, Scott. We really which we could have you stop by with your trailer. Unfortunately, as you and I previously discussed, our liability insurance at the factory won't allow for it. Feel free to stop by anytime for the nickel tour though!
Technical Support
Micro-Air, Inc.
Old 03-18-2017, 01:07 PM   #113
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Well it looks like we may have a warming trend next Saturday!
Name:	Cortland__OH__44410__10-Day_Weather_Forecast_-_The_Weather_Channel___Weather_com.jpg
Tom & Doty
Old 03-18-2017, 07:42 PM   #114
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
I'm installing my black easy start tomorrow, using the instructions Mateo provided, for in the box installation. I'll let you know how it goes.
Toughest part will be working around the solar panels I installed two weeks ago. That was bad planning[emoji33]
Troutboy
Troutboy is offline   Reply With Quote
Old 03-18-2017, 09:01 PM   #115
Rocinante's Avatar
Best wishes for smooth sailing on the install. Pictures, lots of pictures!
Old 03-18-2017, 11:21 PM   #116
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
My bad. Forgot that part!
Old 03-19-2017, 11:30 PM   #117
Troutboy's Avatar
Parker , Colorado
Can Generators Run Both AC's While Boondocking?
Micro-Air Easy Start - or should we say Easy Install
Today I installed the black Easy Start 364 in my 2017 Flying Cloud 23D Bunk. I believe its a Dometic Penguin II. This is a long two threads detailing my experience (needed two threads because of the number of pictures) See picture below below of the unit I installed.
I am a decent do-it-your-selfer, and am comfortable with heights, balance, and working with electrical systems and components (despite having an old nickname of “Sparky”, back when I got paid to work on industrial equipment).
This job was very easy for me, in fact it took about 75 minutes total. One of the hardest parts was gaining access to the right spot on my roof, as I installed 600W of solar panels the week before (Yes, bad planning).
So, to start, I got out the ladder that i use. A nice 12 foot step. I like this because I can actually get above the trailer and step over, no acrobatics required:
This is what the roof looked like before the install. The AC electric box that I needed acces to is right behind the word Dometic in the picture below. When I installed the solar panels, I opted to use square head bolts instead of the big black wing nuts supplied by AM Solar. I figured it would be harder to swipe the panels with normal bolts (I know, if they really want them they will take them).
So I unscrewed the 4 bolts from the solar panel, cut the two cable ties I had installed, and moved the panel over (all from the ladder), this then gave me decent access to the area I needed to work on. See below for what it looked like:
Next job, get on trailer roof and remove the Dometic white cover. This was easy and doable from one side, the side I was on. Note, that this is the awning side, which also gives added safety, as I could sit on my can when working the panel, and have one foot againts the awning (not too much force). It was little tricky as I had to avoid the solar foot mounts, and cable tie attachment points.
The removal of the cover is easy, 4 Phillips head big screws, two on the front, then one on each side near the rear. This is what it looked like after removing the cover.
While I was up here and had it opened up, I took photos of the nameplate data of the unit, compressor, and fan. Its a good idea to have that if you need info off it later. Next I removed two hex-head sheet metal screws that gave me access to the inside if the electrical box. I also had to cut the foam seal as Mateo mentioned to remove the box cover, it was easy. This is what it looked like after removing the cover (Note I flipped the cover up to avoid having to cut the foam seal twice):
Next I removed the bracket off the large silver capacitor. Again, a small hex head sheet metal screw was removed, and the bracket slipped off easily. In order to take the capacitor out, I had to remove the brown wire shown in the picture below, so you need to remember to take that off, and put it back in the same place after you move it to the proper place. I also had to remove the white wire shown in the picture above (the one that shows the screw hole location).
I then removed the capacitor, which gave me access to the small capacitor that needed to be removed next. I also popped out the small bulb like thing with red wires attached, it just snaps out of a bracket attached on the left side of the box. Once this is popped out, you can remove the bracket, its a small phillips head sheet metal screw. Then disconnect the red wire from the small bulb from the silver capacitor.
The other red wire on the small bulb thing is attached to the small brown capacitor that you remove next. A small hex-head screw holds this in place. Remove it, and the brown capacitor lifts right out. See pic below:
Once you have removed the small bulb thing, the small brown capacitor and all associated brackets, you will be left with the open space to install the easy start and relocate the silver capacitor. The picture below shows you the parts that were removed:
The next thing I did was move and relocate the silver capacitor to the left hand side of the box. I couldn't fit a cable tie in any of the holes in the left side as Mateo did in his install. Instead I used a 3M attachment point for the cable tie, the same used to hold down my solar panel wires to the roof. I also reattached the brown wire i removed earlier as noted in the pic. Then I removed the white wire from the capacitor that has a right angle connector as noted in the pic (you may have removed this earlier as I mentioned it in one of the previous photos). You can check that you have the right one, just trace this white wire and it should go out of the box to the compressor. It all fits in nice:
Continued on next post, ran out of picture space....
Troutboy
Old 03-19-2017, 11:35 PM   #118
Troutboy's Avatar
Parker , Colorado
Continued install.....
Next was the Easy start install. The night before I broke off the tabs on the box and removed the sheath as Mateo outlines in his instructions he posted. I also had to bend two of the terminals on the existing board in the electric box as he did so that the easy start would get deeper in the box.
I slid the easy start into its new home and it fit nice, with a little room to spare. I followed Mateos instructions as he laid it out in detail, i suggest you read the PDF he posted the link to the thread earlier in this topic. I had them printed and up on the roof with me.
The first connection i made was the one with the end splice and three wires. This might be confusing as you need two blue wires and the black from the easy start. But there is only one blue wire coming from the compressor! Easy, you need to cut this wire and then splice the two cut blue wires with the black easy start wire with an end splice. See pic below for the wire I am talking about. I then used electric tape around that splice. Note this pic shows the wires before I relocated the capacitor, in case you were wondering why it's back on the right side.
Next I crimped a terminal fitting onto the orange wire of the easy start, and connected it to the silver capacitor, where the other red wire was connected.
Next, remember the first short white wire I had to remove to move the capacitor (picture way above), I cut that connector terminal off and put a yellow butt splice on it. I extended this wire to reach the new location of the capacitor with wire cut from the easy start (like Mateo did), crimped it together, crimped a terminal connector on it, and attached it to where all the other white wires were attached to the capacitor.
Next, i crimped a terminal connector onto the white wire from the easy start, and connected it to the capacitor where all the other white connections were.
The last connection is the brown easy start wire. First, there was the white wire we disconnected from the capacitor that had the right angle terminal and ran back to the compressor. I cut that connector off, and used a yellow butt splice to connect it to the brown easy start wire.
This is what it looked like when done (it's hard to see the end splice with the black and blue wires, its under the wire bundle).
Then I replaced the electric box cover and resealed the foam gasket with contact cement. Note there were several places where the foam seal was not sealed where it was spliced (thanks AS Factory!) so i used the cement there as well. I also noticed some of the AC fins were bent or damaged, so again thanks AS Factory! What sloppy work...
I replaced the Dometic cover, went down into the AS and she fired up right away!!! Put the solar panel back in place, and let it cycle on and off about 6 times to learn.
Thats it, very simple and easy. I never felt like I was in an awkward position and in risk of falling, and also never felt overwhelmed. Mateo’s instructions were great. I was slightly confused by the blue wire and the white wire install (both of these wires come from the compressor, thats why I detailed them above.
It got up to 80 degrees in Denver today, with full sun out. The AS AC was struggling a bit and running non stop to keep the temp at 70. I have seen other posts where people are asking about 1 or two ACs, and I would go two in anything larger than a 23 based on what I saw today.
If you have questions, shoot me a PM.
Troutboy
Old 03-20-2017, 12:08 AM   #119
Troutboy's Avatar
Parker , Colorado
One other note, when you look at the picture of everything I removed, you will see a white wire connected to the small brown capacitor. Obviously, you need to disconnect that white wire from the silver capacitor in order to remove the brown capacitor. Sorry I left that out.
Troutboy
Old 03-20-2017, 06:43 AM   #120
HD Pilot's Avatar
2017 23' International
Decatur , Texas
That's a great post Troutboy! I have a 2017 23FB, so I should have an ac set up just like yours. I hope the black 364 Easy Starts don't run out too quick....
HD Pilot is offline   Reply With Quote
39 degrees while boondocking, anyway to get heat without generators Streaminfree Boondocking 51 07-24-2020 05:01 PM
Run both a/cs at once? Jenniflow Classic Motorhomes 13 05-08-2015 04:44 PM
Generators vs. what they will run Johnnyk777 Electrical - Systems, Generators, Batteries & Solar 4 09-08-2014 11:24 PM
Can you run both Air Conditioners with the Genset? Keyair Classic Motorhomes 4 08-26-2011 05:32 PM
How to run both roof air units RoyTabernick Furnaces, Heaters, Fireplaces & Air Conditioning 2 05-29-2009 08:59 AM
