Old 08-25-2010, 04:13 PM   #15
Splitrock's Avatar
Sioux Falls , South Dakota
Originally Posted by dnssandbox View Post
I feel like I am solving a giant puzzle here.
That's how I felt when I was working on my 7-way plug and the break away switch.
Gary
Old 08-25-2010, 04:21 PM   #16
Coastalview's Avatar
2002 27' Safari
Carmel-by-the-Sea , California
Images: 14
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
Well, I figured out why the Central Control Panel was not working.
I tested the fuses and they were all okay. So, I decided to work backwards. I noticed a white/cream colored cable (looks like and old round phone line) coming out of the right side of the Control panel above the stove. I traced it and found that the cable had been cut and tucked up above they stove.
Why would anyone do that? I just don't get it.
I am still awaiting my manuals, but does anyone know where I might look to find the other end.
I did a cursory below the stove but did not see it.
There was a similar cable below the stove, but that wire looked to braided wires within the shield.
I'll take a look in my manual to give you an idea where to search for the other end of that cut cable. As you can see us 78 Abassador 28's stick together when in need. I have the floor plan like yours with the fuse panel up front with the two batteries and would be your univolt location. My unit hasn't been hacked up so things appear to be in a orderly fashion.
Jeff
AIR: 649
TAC: CA-40
Northern California Airstreamers
Coastalview is offline   Reply With Quote
Old 08-25-2010, 04:43 PM   #17
1978 28' Ambassador
Long Island , New York
Thanks a Million Jeff.. It is great to have shoulders to lean on at times like these.
dnssandbox is offline   Reply With Quote
Old 08-25-2010, 04:57 PM   #18
Mexray's Avatar
1978 28' Ambassador
Morada , California
Here's a good fuse panel to check out - they even have a wiring diagram to take a gander at...
12V RV Fuse Box
sounds like the PO had a problem with the central control panel, and just cut the wires to 'cure' the problem...some of the LED indicators on our panel are intermittent, but it's still usable....
Ray
Ray & Pat; Morada, CA
Old 08-25-2010, 05:50 PM   #19
1978 28' Ambassador
Thanks for the link Mexray. The wiring diagram clears up a lot for me.
Old 08-25-2010, 07:25 PM   #20
stephenh2's Avatar
Tyler , Texas
Not sure if the '78 is same as my '74, but if the Univolt is gone then probably the shunt for the voltmeter in the control panel is gone. The PO probably didn't bother to go to the effort to get the meters working after removing the Univolt.
I also recommend Bestconverters. Bought my Intelipower from them and a new fuse block at the same time. I don't have my control panel working either, but plan on going back and working on it at a later time.
Welcome to the forums,
Stephen
Home again in Tyler, Texas
Please visit any time!
stephenh2 is offline   Reply With Quote
Old 08-25-2010, 08:18 PM   #21
2002 27' Safari
Images: 14
OK, the feed for the control panel is likely coming up behind the spice rack at the back of the stove.
Some things to look at since you don't have a front cover to your fuse panel nor have you received your shop manuals:
ID:	109383   Click image for larger version
ID:	109385   Click image for larger version
AIR: 649
TAC: CA-40
Old 08-25-2010, 10:02 PM   #22
1978 28' Ambassador
Jeff: Wow! exactly what I needed.
This will help me immensely tomorrow. I am tempted to go tackle it now, but my wife is giving me that "don't you dare" look, so I think I will play it safe.
I don't mind sleeping in the Ambassador, but I want it to be my choice
Old 08-31-2010, 12:04 PM   #23
1978 28' Ambassador
Well.. I ordered the replacement 12 volt fuse panel online as well as an intellipower from Best Converters. Thanks to everyone for their help and suggestions thus far.
I am confident that the diagrams above and links posted will make it very simply for me to connect everything when I receive them.
I also received my 1978 printed manual from Airstream. (as a side note it is interesting to discover that Airstream seemed to have used the same manual for all models in 1978 and simply changed the cover and first page to personalize for each model).
I also ordered the CD with a PDF version of the 1978 model year user manual and Service Manual from ebay.
Of course the first thing I did was remove the password and other useless security from the CD so that I could use the file without restrictions, print out pages and not having to type in a password.
My problem however, is I still am having an issue finding out where this wire that was cut from the Control Panel leads to, so that I can pick up the other end. Even with the service and user manual.
I have attached 2 pictures to help clarify what I am facing. The first picture shows the cable coming out of the Right side of the Control Panel above the stove. The second picture shows the cut end of the cable (about 4' later).
This is probably the last major hurdle to overcome with the electrical before I tackle the water pump.
ID:	109842   Click image for larger version
Old 08-31-2010, 12:46 PM   #24
1977 Argosy 24
Milltown , Wisconsin
If the panel showed tank levels it probably goes to your holding tanks.
ventport is offline   Reply With Quote
Old 08-31-2010, 01:30 PM   #25
1978 28' Ambassador
Thanks for the suggestion Ventport. I will go check in that general direction.
Old 08-31-2010, 02:05 PM   #26
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Look around in the outside compartments as well. Ours had an phone isntalled in ours and we found phone wire in the strangest places. Ours ran out the streetside rear compartment door. The phone was in the cabinet above the sink... Just a thought
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 09-11-2010, 11:48 AM   #27
1978 28' Ambassador
Stephen
Still trying to get the Control Panel going. I now have the fuse panel and Intellipower installed and working fine.
I do believe the picture of the wire that looks like a phone line that I posted before is just that. A phone line.
While poking about, I came across 3 other wires below the stove - behind the furnace. One of the wires is red, another is white and they both have a black rubber end on them. The third wire looks to be a ground.
For the life of me, I cannot find where they plug into. They are not long enough to reach the control panel (unless they are coming from the Control panel and plug into something else), so it is possible they connected to an intermediate point.
Any pointers where to look?
Thanks.
Can someone identify this for us please? T&E10876 Fresh Water Systems 3 03-24-2010 11:29 AM
Can anyone identify these? bullydogsmom General Interior Topics 7 04-06-2009 05:20 AM
Please Identify chaimemet Vintage Kin 12 12-08-2008 08:49 AM
Help identify cosmotini Off Topic Forum 17 01-04-2008 11:22 PM
Can Anyone Identify? rhoward Airstream Trailer Forums 12 12-11-2007 06:42 AM
