Old 07-03-2014, 06:26 PM   #1
AirConditioner's Avatar
Bye Bye Univolt- Hello WFCO
After 10 years I thought it was about time to replace the Univolt. For a few years the Univolt has been "browning out" and totally dropping out. I traced this to a high resistance fault in the Univolt's negative output through the ammeter shunt. My output was typically 11.4 volts to 9.5 volts to 0 volts on full failure.
The copper "rivet" shown by the arrow is actually the flat end of a threaded stud that is fed from the reverse by a cable bolted to it. This is the main negative output from the Univolt and also the connection point for the trailer negative lead. Corrosion had built up under this rivet which resulted in an intermittent connection. This resistance caused a corresponding heat build up...not good.
The images show my layout and installation of a WFCO 65 amp, three stage converter, a set of breakers, and a new fuse panel.
I'm not recommending this to anyone, but only present this as how I did the replacement. The result was 13.8 volts and really bright lights!
Hope this is helpful!
ID:	215563   Click image for larger version
ID:	215565   Click image for larger version
AirConditioner is offline   Reply With Quote
with a screach and burning rubber, it's bye bye belt !!! kepko Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-06-2008 02:34 PM
Change-out Univolt for WFCO Bulldogger Batteries, Univolts, Converters & Inverters 10 11-09-2007 08:11 PM
Bye-Bye Univolt tamis Electrical - Systems, Generators, Batteries & Solar 14 02-02-2007 06:10 PM
Bye Bye Dinette? Foiled Again Off Topic Forum 13 02-04-2006 07:47 PM
Bye bye Miss American Pie Rog0525 Our Community 4 04-13-2003 10:18 PM
