Old 09-17-2016, 08:46 AM   #1
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Bummed... No Parallex 5300 series upgrade available.
So, I purchased a PD4655 for my Classic as an upgrade and upon attempting the install, The directions didn't match the wiring.
I gave up and started searching and returned the PD4655.
The 2016 Classic, at least mine, has a Parallex 5300 series or 5355.
I searched the web and could not find an upgrade to a 4 stage charger available, anywhere.
Do more knowledgeable and experienced Airstreamers have any suggestions. If a 4 stage upgrade is on the market??
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 09-17-2016, 02:27 PM   #2
New Borockton , Alabama
Images: 21
The 4655 doesn't fit the 555 or new 5355 and there is no direct kit however you can still get a 4 stage charger like the Boondocker. I can't post a direct link but you can look for it. Many owners of the 5355 have already done it and it was actually a member here that sent in the photos. Essentially you need a hard wire deck mount converter like the Boondocker 60 and you can reuse your existing fuse board and attach it direct to the new converter. Works great and you get 4 stage charging and much better battery maintenance especially if you store your Airstream with hook-ups. Good luck.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 09-17-2016, 04:22 PM   #3
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Thanks for responding 66Over,
I saw the Boondocker but it looked complicated just through quick browsing.
Please send or post the links and I will delve more into it.
We are full-timeers so I think I would like an 4 stage upgrade.
Sphere Guy
AIR 50601
Old 09-17-2016, 04:24 PM   #4
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Sorry
Pardon, 68 Overlander, I mis-typed your handle.
Sphere Guy
AIR 50601
Old 09-17-2016, 04:37 PM   #5
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
AH, Got it 68 Over.
Sphere Guy
AIR 50601
Old 09-17-2016, 05:03 PM   #6
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Randy or any one else, can the PD9260C be used in the same way and is there a reason to prefer the Boondocker over Progressive Dynamics? I have a 2016 FC with 50 amp service.
Frank & Fran
2016 27' FC FB with 400 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 09-17-2016, 05:16 PM   #7
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
A more expensive option is the Magnum 1012 1000w Inverter/Charger. Customizable battery charging parameters using the optional Magnum display. This allows you to set the exact charging parameters for any battery technology. This would replace your stock inverter. Use a new AC and 12v panel from Progressive Dynamics. If you think you would need more batteries and more inverter power Magnum offers 3000w versions. You could then set up all 110v receptacles for inverted power and isolate fridge 110v, A/C, microwave and water heater circuits for shore power only. Probably need to get someone to install it for you. A&P Vintage Trailer Works is in Paradise, TX and performs this type of work.
Kelvin
Old 09-17-2016, 05:20 PM   #8
Images: 21
Yes it can except its not available in hard wire configuration so you will need to install a duplex or chop the plug off to wire it which voids the warranty. You could also build a pigtail I suppose but since they do the same thing, the Boondocker seems to be the easiest way. Both are available however and do great. We've done it both ways.
Old 09-17-2016, 05:33 PM   #9
Images: 21
Kelvin
Most Airstreams don't have an inverter except newer ones or those that have added one. If I were installing an Inverter/Charger, I would use the Samlex EVO. Same programmable feature with better surge power, has transfer relay, etc and much less $$.
Modern switching converters like the PD and Boondocker have 4 stage charging that is great for flooded and AGM batteries. On my 11th year with my Lifeline batteries so hard to argue with small minute differences between battery X vs battery Y recommendations. It just isn't that big of deal unless your using undesirable Gels for instance.
Some prefer to upgrade the converter and add a separate stand alone inverter too,and it makes most sense for most since it does save a lot and more DIY friendly.
Old 09-18-2016, 03:00 PM   #10
bugdoc's Avatar
2007 25' Safari FB SE
Try this link: http://www.bestconverter.com/Paralla...e_ep_25-1.html
This is a hardwired conversion with lots of pictures as to how to install.
bugdoc is offline   Reply With Quote
Old 11-21-2016, 03:17 PM   #11
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Have you considered a 4400 TAU upgrade for your 5300 panel? It adds variable voltage and temperature compensation..
If you could have a superpower, what would it be?
I chose America
Bigventure is online now   Reply With Quote
Old 11-21-2016, 04:58 PM   #12
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Thanks Bigventure, I will look it up.
Sphere Guy
AIR 50601
Old 11-21-2016, 05:52 PM   #13
fran&frank's Avatar
Does anyone know any details about the Parallax 4400 TAU, I looked at their website and the owners manual but their aren't many details. They mention temperature regulated charging, but is this actually a multistage charger, and what are the different charge modes and voltages?
Frank & Fran
Equalizer Hitch
Old 11-21-2016, 07:00 PM   #14
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I call them and they technician told me it does vary the voltage according to temperature.
I chose America
Parallax 5300 Ohiobrits Batteries, Univolts, Converters & Inverters 9 03-09-2015 06:30 PM
So sad again, my Parallex 7300 converter burned out. Literally. J5MM Batteries, Univolts, Converters & Inverters 25 12-10-2013 07:51 PM
really bummed - took a hit funkill Ribs, Skins & Rivets 43 01-21-2010 12:21 PM
BigJohn's bummed camperski Our Community 23 05-07-2008 06:26 AM
'96 Tahoe with 5300 Vortec Cracker Tow Vehicles 13 03-18-2006 04:54 PM
