Old 06-16-2007, 08:41 AM   #1
2005 28' International CCD
Golden Valley , Minnesota
Rivet breakaway pin work with no battery?
If you remove the deep cycle batteries from trailer, will the breakaway switch still work? I am in the process of installing 2 Sears Diehard Platinum PM2-34M batteries in my 2005 International. (I have been remiss about battery maintenance in the past.) I store my travel trailer about an hour from my house. If I charge the batteries before I head off to storage, then remove them for the winter, will the breakaway switch still work in case of accidental separation from the tow vehicle? Where does the breakaway switch get its power from?
HilaryStep is offline   Reply With Quote
Old 06-16-2007, 08:44 AM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The switch will still work, but the brakes wont! The switch merely connects the electric brakes to a power source. You need a power source. You could use a motorcycle battery since you would at most make one stop, but you must have a source on the trailer. While connected to you tow vehicle, the battery in it will work the trailer brakes, but only while the umbilicle is connected. If the trailer gets loose the umbilicle will be disconnected. Welcome to the forums!
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-16-2007, 08:57 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It depends
On my 75 TW the power to the switch comes from the battery and/or the charge line from the TV. In that case the break away would work untill the cable from the TV unhooks. At that point the breaks would unlock and the trailer is on it's own. Not a good situation.
Richard
house batteries wb13798 Mechanics Corner - Engines, Transmission & More... 16 02-07-2006 07:41 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
61 Bambi Battery 61BambiCanada Electrical - Systems, Generators, Batteries & Solar 0 05-21-2002 10:53 PM
