Old 12-18-2018, 07:44 PM   #1
2017 27' Flying Cloud
Fort Worth , Texas
BMV-712 Battery Monitor Temperature Sensor
Hi,
In the process of rewiring the battery part of my Airstream and decided now would be a good time to add a temperature sensor to my Victron battery monitor. I ran the wires today and discovered it is about 6-12" too short. I'm surprised it is as short as it is. Anyone else run into this problem?
The solutions don't really look good. I could just cut the cable and add new ends, but the one end is pin connections and I'm not familiar with how they are attached nor what size they are. The other end fits on the battery terminal but is odd in that the wires are probably something like 18 gauge. No idea where to find that connector? The only other option would be to cut the wire and have two connectors on each wire so that I can use the two ends that are already on the cable.
Thanks!
billrector is offline   Reply With Quote
Old 12-18-2018, 09:35 PM   #2
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
What I’ve found says there is very little voltage flow (AMPS) on the temp sensor wire so you can cut that wire and splice without changing the accuracy of it.
Source says, Cut in the middle solder the splice and heat shrink cover joint to protect. Use at least 22ga wire for extension.
http://www.cruisersforum.com/forums/...re-158294.html
Old 12-18-2018, 11:04 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
cut in the middle and use the same wire gauge
the end tip is a thermo couple
do NOT modify it
waninae39 is offline   Reply With Quote
Question regarding Victron BMV-712 billrector Batteries, Univolts, Converters & Inverters 26 05-30-2018 04:21 PM
BMV-712 midpoint two 6V AirstreamCSH Batteries, Univolts, Converters & Inverters 0 05-05-2018 10:43 PM
victron BMV-712 with battery temp probe waninae39 Batteries, Univolts, Converters & Inverters 1 04-23-2018 08:53 PM
Sync settings for Lithium battteries - BMV-712 Smart waninae39 Generators & Solar Power 0 03-30-2018 01:58 PM
Victron BMV-712 install in 2017 30 International dmcgaugh Batteries, Univolts, Converters & Inverters 3 03-09-2018 01:24 AM
