Old 03-06-2011, 06:39 PM   #15
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
From the age of the Airstream the blue wire should be the charge line.
That said the wiring could have been changed by a previous owner.
Take a look the pic I posted above and this PDF.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-12-2011, 10:33 PM   #16
gary larocca's Avatar
1966 24' Tradewind
oldham,co. , Kentucky
Thanks for the info. I will put a meter to it.
gary larocca is offline   Reply With Quote
Old 03-17-2011, 08:15 AM   #17
geodazed's Avatar
1969 31' Sovereign
1966 24' Tradewind
Franklin , North Carolina
Smile How did you finally hook up your blue wire?
Originally Posted by gary larocca View Post
So..it goes to the....positive on the inverter...or neg.? It has a red(positive)&white(neg.)already hooked on the Inverter,which puts out 12v
Hi Gary,
This is my first post but second airstream. First airstream was a 1969 31 footer which I had in Idaho many years ago.
I now have a 1966 trade wind and am hooking up a new progressive dynamics charger/power supply to replace the old univolt which had three wires hooked up. Blue wire was labeled on old univolt "battery positive", Red wire labeled "load positive" and white labeled "ground"
Can I just combine red and blue wires into the positive dc connector on the new charger/power supply or do I need to rewire the low voltage fuse block somehow?
John Pittman
geodazed is offline   Reply With Quote
Old 03-17-2011, 08:42 AM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Univolt
When I replaced the old univolt here is the way I wired mine. You need protection on all of your branch circuits.
Name:	12 volt power system-R.jpg
Atwood water heater burnt wire richinny Water Heaters, Filters & Pumps 5 06-21-2011 07:27 AM
Recommended 110V Wire Gauge SilverHoot Electrical - Systems, Generators, Batteries & Solar 13 02-28-2011 09:42 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
'89 Excella, Mystery wire bundle, hitch area, photos cjack99 1987 - 1989 Excella 3 01-27-2011 04:03 PM
Landscape Wire Brianv512 Electrical - Systems, Generators, Batteries & Solar 13 01-06-2011 10:00 PM
