Old 04-26-2010, 07:50 AM   #1
2011 28' Flying Cloud
chanhassen , Minnesota
Best way to keep 12V charged when not using unit
Hi,
Wondering best way to keep 12V battery charged when A/S sitting at home and not being used - I could just keep the power cord plugged in to an a/c outlet or use a trickle charger.
What works best?
Ken in MN
kentuvman is offline   Reply With Quote
Old 04-26-2010, 08:11 AM   #2
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Ken,
I don't know if it's the "Best way" however in the Winter I store my batteries up off the floor and hook them to a trickle charger. During the "Camping Season" I just leave them hooked to the AC shore power. Mine are Optima batteries and going well into their fifth year of service with plenty of life left according to my meter.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 04-26-2010, 08:19 AM   #3
Member
D. Novak's Avatar
1974 25' Tradewind
1976 27' Overlander
Stillwater , Minnesota
I usually just disconnect the negative terminal if not using the trailer for an extended period of time during warmer seasons. Take them inside for the winter and trickle charge occasionally. I get about five to six years out of a deep cycle.
D. Novak is offline   Reply With Quote
Old 04-26-2010, 09:21 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Do not just leave it plugged into 110. The older chargers did not have a Management system in them and over time if left on will boil the batteries. If you have a trickle charger use it from time to time.
Consider a new converter that has a management system.
2004 Excursion 4x4
Old 04-26-2010, 10:01 AM   #5
I do have a new converter - okay to leave it plugged in? I do use the trailer as a refuge when things get too busy in the house.
Old 04-26-2010, 11:49 AM   #6
2010 27' FB Classic
N/A , Texas
Howie,
Do you know if new(2009-10) trailers have the management system converters in them from the factory, or, are they the plain Jane model? How can you tell what you have?
Old 04-26-2010, 12:42 PM   #7
Gator113's Avatar
2007 25' Classic
Port Angeles , Washington
Originally Posted by Bluto View Post
Howie,
I have the same question for a 2007 25' Classic Limited.
If need be, I'll call my dealer. I didn't know to ask when I bought it.
It does have a solar panel and the gizmos that go with that, that also tells me the condition of the batteries.
Gator113 is offline   Reply With Quote
Old 04-26-2010, 02:04 PM   #8
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
If you have a true "3 stage" charger (such as the IOTA DLS 45 that I installed this past weekend) you should be able to leave it plugged in all of the time as it will maintain a float charge. We would need to know the brand/model to see if it was a 3 stage.
Some of this might be impacted by the types of batteries you use. I few years ago I switched to two 6V Trojan T105s as I was sick of the standard "Deep Cycle" batteries not holding charges etc. I find the Trojans just truck along and even hold a good charge over the winter when I disconnect them. We camp from mid March through Nov so our off season is onlyl 3 months or so.
Swapping the old Magnatek in my AS for the IOTA was the first thing I did after a I purchased the trailer. BTW as many have said on here, kudos to Randy at Bestconverter.com, he is great to work with and VERY responsive.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
12v
Are my batteries being charged? Bobdes Electrical - Systems, Generators, Batteries & Solar 13 12-23-2009 06:47 PM
Battery Charged but Electric Items Only Working When Plugged in..help?!?!. ericwarren Our Community 12 05-07-2009 08:24 AM
Battery's gurgling while being charged? Kistler Batteries, Univolts, Converters & Inverters 4 11-16-2004 11:05 AM
Can't get batteries charged -- why not? neil.ervin Batteries, Univolts, Converters & Inverters 23 11-14-2004 07:24 PM
Electrically Charged Trailer - Help! Joe Z Electrical - Systems, Generators, Batteries & Solar 40 10-12-2004 11:04 AM
