Old 06-27-2012, 12:15 PM   #1
1966 26' Overlander
Conover , Ohio
best Univolt replacement?
The univolt was cooked on our 66 Overlander I am redoing. I found a 35A WFCO 3 stage converter for $180. I have looked at InteliPower and Iota units as well, but they are pushing $300 if they have 4 stage charging. Are there any other converters I should consider?
The other part I am wondering about, is that I doubt if we will be camping much at all without a 110 volt hook up. Is there a simpler/less expensive alternative?
TomE
project66 is offline   Reply With Quote
Old 06-27-2012, 12:19 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
That price is high, and I have an older 45A WFCO that offers the added "benefit" of variable output, even when the demand isn't varying, so the lights get bright and dim over time.
bestconverter.com (a commercial member of these boards) has a number of options for significantly less than that.
David
Old 06-27-2012, 12:21 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The Progressive Dynamics 9200 series has been highly recommended to me by several members here. Available from BestConverter - Converters, Inverters, Electrical Supplies, Electronics
MICHAEL
Old 06-27-2012, 12:27 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We used a Progressive Dynamics PD9245 45 Amp Converter Intellipower in both our '56 Safari and our '64 GlobeTrotter (since sold). Works great.
I just purchased a Progressive Dynamics 4060: 60 Amp Converter + AC/DC Distribution Panel for my Serro Scotty. I don't need 60 amps - but I like the compact size of the all-in-one unit, it looks great and I think in the long run ends up more ecnomical because you don't have to get the fuse box, distribution panel & other parts separately like you do with the one we used in the Safari & GT.
Shari
Univolt question Stonew98 Batteries, Univolts, Converters & Inverters 11 12-19-2011 08:15 PM
Weird Univolt noise (no not the hum) and power flicker ovrteakettle Batteries, Univolts, Converters & Inverters 12 12-07-2011 11:31 PM
Univolt on a 1976 Caravanner wba1 Batteries, Univolts, Converters & Inverters 12 07-27-2011 07:13 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
