07-20-2017, 03:40 PM
1973 25' Tradewind
Sanger
Best Replacement for Univolt Converter?
What is currently the best replacement converter? I want to replace a Univolt on a 1973 Tradewind. Currently a 55 amp. Like to go to 65 amp if possible. Currently there is no fuse box so I'd like to install a fuse box too.
07-20-2017, 03:49 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
I would recommend a Progressive Dynamics 9260 with the fuse box and pendant form Vintage trailer supply. I use these in all my rebuilds. Single and double battery systems.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
07-20-2017, 03:58 PM
1973 25' Tradewind
Sanger
9260 vs 9260C "with charge wizard"
Thanks for your quick reply. do you have a preference of the 9260 vs. the 9260C that includes the "charge wizard"?
07-20-2017, 06:16 PM
1968 24' Tradewind
Oxford,
, Mississippi
You might want to give Randy at http://www.bestconverter.com
a call. He sells of converters from several suppliers and can suggest the best converter technology for your situation.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
07-20-2017, 09:18 PM
1997 30' Excella
San Antonio
9260C is what I have and the fuse box.
Bruce
10-20-2018, 01:33 PM
Indian Trail
, North Carolina
Do you have a diagram for the wiring of the Progressive Dynamics Converter and fuse box ? I’m replacing my old Univolt and remote fuse panel in my 79 Sovereign
10-20-2018, 01:48 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The same 120V power circuit that fed the Univolt now feeds the new converter charger.
You label each of the wires as you pull them off of the old panel and then re-wire them to the new panel. They get the same fuse size on the new panel as they had on the old panel. The label sticker on the new panel gets a description of the circuit on it. If you need info on what circuit is what, the manual (still available from Airstream) is the place to go.
10-20-2018, 01:49 PM
1982 31' Airstream 310
champaign
10-20-2018, 10:04 PM
New Borockton
, Alabama
Originally Posted by mayco
This is so hard for people to understand. They don't describe the different types of power supplies (converter/chargers) there are, what models fit with what type and size converter, the difference between charge algorithms of each, no mention of desulfation, equalization, ability to charge lithium, AC ripple, etc. I have heard of every comparison since the early 70s but this is very hard to believe this was an accurate comparison. I would love to see the data on noise, charge rates, float voltages, power factor correction, etc. What we use is a simple test set and 15 years of feedback from he field. We could in no way suggest what each customer needs with out that feed back.
What if I like the PD 9260 but have a 7345? Will it fit?
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
10-21-2018, 12:13 AM
1980 24' Caravelle
vallejo
[ put a pd 9260 in my 80 caravelle: also added a new fuse block. it has worked well these last 2 yrs, plenty of power for the trailer and all my ham gear. kurt
10-21-2018, 09:39 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
I'm with Randy on this one. Both articles could be titled:
..... best converters we could find somebody to pay us to write up an article on ....
There is an unfortunate lot of this sort of stuff up on the web. It's not just specific to the RV world. One might even come up with a term for it .... errrr ... ummmm... what was that phrase I heard once .... ummm.... fake news was it?
